Auxiliary Heater Audi Q7 Compatibility
clio2k
Post23-10-2016, 12:25    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
Good morning.
Even after repeatedly resetting it via VCDS, I can't get my auxiliary heater in my Q7 (2009 model) to work permanently... so, I need a replacement.
Currently, a 4L0265105K is installed. Can I easily replace it with a 4L0265105R and simply have the component protection removed at Audi, or is the new 4L0265105R not compatible with my 2009 vehicle?
Thank you in advance!
Translated on 14-10-2026, 3:51.
Post23-10-2016, 13:10    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
Why don't you just fix the auxiliary heater? It would probably be easier than experimenting with potentially suitable heaters...
And if the problem, for example, is due to leaky fuel lines, a new heater won't help at all. icon_idea.gif
Translated on 14-10-2026, 3:52.
clio2k
Post23-10-2016, 13:15    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
The error message is consistently "Fan short circuit to ground"... it could be the fan motor or the control unit. Therefore, I would rather invest directly in a used auxiliary heater with the identifier "R" (latest revision).
Everything is tight, but sometimes it also leaks.
Translated on 14-10-2026, 3:53.
clio2k
Post30-10-2016, 19:04    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
As I suspected... The error code "blower motor short circuit to ground" has cleared. I actually ordered and installed a new blower motor.
And as previously suspected, it's the control unit icon_sad.gif. The same error. Does anyone have experience with the compatibility of the different revisions?
"Thank you."
Translated on 14-10-2026, 3:54.
Post31-10-2016, 11:40    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
You could have someone check in the AKTE system icon_smile.gif to see which ones were installed in your model.
"Caution: Other revisions for different models may not work or may not function as expected, especially if the communication with the other control units is even slightly different. I strongly recommend obtaining an identical model, meaning one with the same VAG part number."
clio2k
Post31-10-2016, 12:27    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
The problem is that it's not easy to find an identical model icon_sad.gif. The K models are probably very rare....
Translated on 14-10-2026, 3:55.
Wiesel
Post31-10-2016, 13:53    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
I was just talking to my parts supplier, and he didn't have anything in stock.
to do icon_smile.gif - that's why I asked about that part).
If you currently want to buy a car from a dealership, you will receive...
The official replacement was an R. In between, there were also the letters M and P.
He didn't immediately see if this would require any other changes.
"You might be able to find one for around €1,000."
Micha
Translated on 14-10-2026, 3:56.
clio2k
Post31-10-2016, 15:03    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
Wow, great! Thanks for the information. I guess I'll try using an R-model control unit and just have the component protection removed.
Thank you!
Translated on 14-10-2026, 3:57.
clio2k
dieselschrauber and Wiesel likes this.
Post11-11-2016, 19:23    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
Okay, just to be complete... I've now installed the model 4L0265105R in my car, which is a 2008 model. After the component protection was removed at the Audi dealership, the auxiliary heater is working perfectly again.
Replacing the auxiliary heater with a newer revision is therefore possible without any problems.
Best regards, Holger.
Dipl.-Ing. Elektrotechnik
spez. Elektromagnetische Verträglichkeit
Post11-11-2016, 19:30    Subject: Auxiliary Heater Audi Q7 Compatibility Quote
Thank you for your feedback!
Translated on 14-10-2026, 3:58.
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Heater Error 02085: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary Heater Upgrade for Parking Heaters Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater Unlock for Parking Heater On-Board Diagnostics (OBD)
No new posts Auxiliary Heater for Audi A4 2.5 Qtip Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater Conversion to Stand Heater On-Board Diagnostics (OBD)
