Error 4875: Coolant Pump 2
Florian320
2004 Audi Cabriolet
Post25-11-2016, 17:27    Subject: Error 4875: Coolant Pump 2 Quote
Good day.
I just read the following error code from a friend's car: the engine check light is coming on intermittently.
Does the smell indicate a sensor or cable problem, given the coolant temperature of -273.1° (absolute zero)?
Could a connector possibly have a manufacturing defect?
Has anyone else encountered this error before?
Friday, November 25, 2016, 4:00:56:63257 PM.
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 8.1 x64.
VCDS Version: RKS 16.8.0.1
Data as of: 20160808 DS254
Vehicle Identification Number: WAUZZZ4F4AN012XXX Vehicle Registration Plate: HEI J
Mileage: 118,070 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 4F (4F0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 4F 52 53 55 56 5F 62 69 72
76
Vehicle Identification Number: WAUZZZ4F4AN012XXX Mileage: 118,070 km
Address 01: Engine Control Module (J623-CAHA)
Label file: DRV\03L-906-022-CAG.clb
Part number SW: 03L 906 022 FG, Part number HW: 03L 906 022 FG.
Component: R4 2.0l TDI, Part Number: H01 9978.
Revision: 11H01--- Serial number:
Encoding: 010D002C18072920
Operating number: WSC 24092 002 1048576
ASAM Dataset: EV_ECM20TDI03L906022FG A01010
ROD: EV_ECM20TDI03L906019L.rod
VCID: 6FEA6C0CB66A153A4B-803A
"1 error found:"
4875 - Coolant pump 2.
P261A 00 [040] - Interruption.
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 254
Mileage: 117,259 km
Date: 2016.10.29
Time: 10:18:20
Motor speed: 1398.00 rpm.
Normalized load value: 52.2%
Vehicle speed: 21 km/h
Coolant temperature: 37 °C
Intake air temperature: 15 °C
Ambient air pressure: 1020 mbar.
Voltage at terminal 30: 13,260 V.
Lost count after OBD: 40
Crankshaft speed: 1548.0 RPM.
Vehicle speed: 38.07 km/h
Board voltage, class 30: 14000 mV.
Exhaust gas recirculation cooler pump: Target value: 95.0%.
EGR Clg st Ctl Val Bits mp-Bit 0: 0
EGR Clg st Ctl Val Bits mp-Bit 16: 0
EGR Clg st Ctl Val Bits mp-Bit 24:0
EGR Clg st Ctl Val Bits mp-Bit 8: 7
EGR Clg st Mon-Bit 0: 0
Coolant temperature at the radiator outlet: Actual value: -273.1 °C.
Readiness: 0 1 0 0 0
Translated on 05-07-2026, 19:03.
Post25-11-2016, 18:12    Subject: Error 4875: Coolant Pump 2 Quote
It's possible, but I'd like to take another look at the sensor reading directly, just to make sure the boundary conditions weren't recorded incorrectly. After that, check the cables. If everything is okay there, it will probably be a new pump that's needed.
Translated on 05-07-2026, 19:08.
Florian320
2004 Audi Cabriolet
Post25-11-2016, 20:14    Subject: Error 4875: Coolant Pump 2 Quote
Thank you, Rainer. I will pass that along.
Translated on 05-07-2026, 19:09.
Post02-12-2016, 14:04    Subject: Error 4875: Coolant Pump 2 Quote
With mileage exceeding 100,000 km, the failure of the electric auxiliary coolant pump is not uncommon. Wouldn't be the first.
Florian320
2004 Audi Cabriolet
Post02-12-2016, 22:09    Subject: Error 4875: Coolant Pump 2 Quote
Okay, thanks, I'll pass that along.
No new posts P261A, P261B - Pump for coolant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2185 - Coolant Temperature Sensor, High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Headlight Washer Pump Leak - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ZV Pump Error MWB 007 On-Board Diagnostics (OBD)
No new posts V6 TDI VP44 error: injector control valve failure, pump d... Diesel Engine Technology
No new posts Intermittent fault: Engine control unit and pump-nozzle v... Diesel Engine Technology
No new posts Coolant G11: Buy Online & Save! Diesel Engine Technology
