tdi-seppl Blaumann
Joined: 02/01/2003 Posts: 44 Karma: +6 / -0 Location: Regensburg
14-10-2003, 16:25 Subject: Should the water pump be replaced after every timing belt change? |
hello,
a friend (car mechanic)
He told me that after every timing belt replacement, the water pump should also be replaced at the same time because there have been problems with it in the past. Is that really necessary?
Do you always exchange them for the same thing?
(1 TDI, model year 1994)
Hi TDI-Seppl, Baust Du Turbo an Diesel,lÀuft Diesel wie Wiesel
Translated on 09-07-2026, 10:38.
Marco Guest
14-10-2003, 17:03 Subject: Should the water pump be replaced after every timing belt change? |
'Well, if the water pump is replaced at all, it's done together with the timing belt, not afterwards. It makes sense to replace the water pump at the same time because if it fails, the timing belt also needs to be replaced, which can result in very high repair costs, especially with VAG vehicles. In this regard, I have to commend Opel; they replace the timing belt on a Opel Corsa with a 1.2-liter engine for just 160 euros!'
Translated on 09-07-2026, 10:39.
Albrecht Profi-Schrauber
Joined: 05/12/2002 Posts: 284 Karma: +10 / -0 Location: DD
14-10-2003, 18:21 Subject: Should the water pump be replaced after every timing belt change? |
Quote: | | It simply makes sense to replace the water pump at the same time because if it fails, the timing belt | also needs to be replaced.
"...but this is not the case for the 1Z and AFN engines. In those engines, the timing belt only drives the oil pump, crankshaft, and ESP (electric steering pump)."
You can therefore avoid the hassle of changing providers.
Albrecht. 01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
Translated on 09-07-2026, 10:40.
joergs Guest
14-10-2003, 18:24 Subject: Should the water pump be replaced after every timing belt change? |
I agree with my predecessor! And if she has one, you can easily replace it without the timing belt.
Marco Guest
14-10-2003, 18:27 Subject: Should the water pump be replaced after every timing belt change? |
Wow, I've stirred up quite a discussion! However, the statement made by the car mechanic is indeed correct for engines where the water pump is driven by the timing belt.
Translated on 09-07-2026, 10:41.
joergs Guest
14-10-2003, 18:37 Subject: Should the water pump be replaced after every timing belt change? |
Well, I certainly stirred things up! However, the statement made by the automotive mechanic is actually correct for engines where the water pump is driven by the timing belt.
yes and no!
I don't think a water pump only lasts 90,000 km! The one in my 1Z engine has survived two timing belt changes! Of course, it's not a guarantee! And if it fails between two timing belt changes, that's annoying. But, as I said, it *can* happen, but it doesn't *have* to.
or do you get a new leg if you break your foot? However, from a purely precautionary perspective and considering the potential for earning money, the statement is certainly true!
Translated on 09-07-2026, 10:42.
Marco Guest
14-10-2003, 19:35 Subject: Should the water pump be replaced after every timing belt change? |
I think that the relatively low price for a new weapon is not proportional.
Regarding the subsequent costs, these are caused by a stuck valve. For my part, I would always choose to replace it.
Translated on 09-07-2026, 10:43.
Gremlin Guest
14-10-2003, 20:15 Subject: Should the water pump be replaced after every timing belt change? |
In diesem Punkt muss ich Opel mal loben, den ZR bei einem Opel Corsa mit 1,2 Liter RasenmĂ€hermotor wechseln die fĂŒr 160 Euro!
Let's talk about changing the timing belt on a 1.6D engine... or maybe on a 16V engine.
CU Gremlin.
joergs Guest
14-10-2003, 20:49 Subject: Should the water pump be replaced after every timing belt change? |
Regarding the subsequent costs, these are caused by a stuck VAPU. For my part, I would always choose to replace it/have it replaced. }
'I think I paid around 80 or 120 euros for the exchange of the 1Z [component]. Changing the timing belt on a 1Z took me just over 4 hours as a beginner! And what's the problem with that?!'
But, just to be on the safe side, it's okay to change it! (If you have the money for it, of course!)
Translated on 09-07-2026, 10:44.
Bertil Profi-Schrauber
14-10-2003, 21:15 Subject: Should the water pump be replaced after every timing belt change? |
Gremlin wrote: | Marco wrote: | | In diesem Punkt muss ich Opel mal loben, den ZR bei einem Opel Corsa mit 1,2 Liter RasenmĂ€hermotor wechseln die fĂŒr 160 Euro! |
CU Gremlin |
... or with the 1.7D ISUZU engine ....  GruĂ Bertil
Translated on 09-07-2026, 10:45.
