Bugeye01
06-01-2017, 20:51 Subject: Honda Accord Fuel Injector Assembly |
Good evening.
I just stumbled upon this forum and immediately have a question, or rather, I need your help.
A friend of mine has a leaky fuel injection pump (2.0 TDI - 105 hp - diesel). He disassembled the pump and installed a new seal. However, the car won't start now. He didn't remove the top cover, but rather disassembled it from the part underneath, where you can see the control plunger (?) and in the detached section, there's the eccentric shaft (?).
The throttle valve and the eccentric shaft were both moved (while they were disassembled). I believe it's always a good idea to mark everything before taking it apart, but that wasn't done in this case.
How can I reassemble the pump correctly so that the car will run again? I hope someone can help me. If pictures are needed, I can take some.
"I apologize if the technical terms are not correct or if I have explained something in a roundabout or unclear way."
Thank you in advance.
Best regards.
Translated on 02-08-2026, 17:58.
06-01-2017, 22:51 Subject: Honda Accord Fuel Injector Assembly |
I highly doubt that the pump can be repaired and made to work again using common household items and a reasonable amount of time.
I would put the pump to the test at the Bosch service center.  MfG. Michael
Translated on 02-08-2026, 18:00.
Profile PM Garage |
Bugeye01
06-01-2017, 22:58 Subject: Honda Accord Fuel Injector Assembly |
I've now read up a bit, and the part that was unscrewed was between the mixing chamber and the pump housing.
I was hoping there might be a template or some measurements available. Surely Bosch doesn't test every single pump individually, do they?
Thank you for the quick response.
Best regards.
Translated on 02-08-2026, 18:01.
06-01-2017, 23:02 Subject: Honda Accord Fuel Injector Assembly |
Bugeye01 wrote: | | I had hoped that there would be a template or measurements available, surely Bosch doesn't put every pump on the test stand, do they? | Because with a part like this, even a loose tolerance of 1/10mm can make all the difference in whether it "works" or "doesn't work," naturally.  MfG. Michael
Translated on 02-08-2026, 18:02.
Profile PM Garage |
Bugeye01
06-01-2017, 23:26 Subject: Honda Accord Fuel Injector Assembly |
I wouldn't have expected that  .
Do you happen to know how much that might cost?
Best regards.
Bugeye01
08-01-2017, 15:16 Subject: Honda Accord Fuel Injector Assembly |
The pump needs to be placed on a test stand; that's now clear. But to do that, it has to be removed. What should be considered? Can I mark the pump so that I can reinstall it later without any problems? This means fixing the camshaft gear, marking the belt and pulley of the pump, and precisely marking the position of the pump.
Is that possible, or should I discard this idea?
Thank you.
Best regards.
Translated on 02-08-2026, 18:03.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
11-01-2017, 11:01 Subject: Honda Accord Fuel Injector Assembly |
Support for diesel engine technology should be posted in the "Diesel Engine Technology" forum, where you, as a non-customer, do not have writing permissions.
Translated on 02-08-2026, 18:04.
Profile PM WWW Garage |
