TDI BKS Engine: Troubleshooting Electronic Issues
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
arthur
2007 Volkswagen Touareg
Post06-01-2017, 16:26    Subject: TDI BKS Engine: Troubleshooting Electronic Issues Quote
Hello everyone,
Do these three error entries belong together?
"Interruption and short circuit" doesn't read well.
Please provide the scan so I can translate the text from German to English.
VCDS version: RKS 15.7.4 running on Windows 10 x64.
Data as of: 20160602
Friday, January 6, 2017, 1:56:01:39776
Vehicle type: 7L (6N0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 18 19 22 34 36 37 3C 46 55
56 68 69 6D 76 77
Vehicle Identification Number: WVGZZZ7LZ7D078792
Mileage: 182,970 km
01-Motor electronics -- Status: Error 0010.
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
06-Passenger seat adjustment -- Status: OK.
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
22-All-wheel drive -- Status: OK 0000
34-Level regulation -- Status: OK.
36-seat adjustable passenger seat -- Status: OK 0000.
37-Navigation -- Status: OK 0000
3C Lane Change -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
68-Wischerelektronik -- Status: OK 0000
69 followers -- Status: OK 0000
6D tailgate -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking assist -- Status: OK 0000
77-Phone -- Status: Error 0010.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module
Label file: DRV\059-907-401-ASB.clb
Part number SW: 7L0 907 401 D, HW: 7L0 907 401 D.
Component: 3.0L V6 TDI, part number A000AG 0030.
Revision: --H04--- Serial Number: VWX3Z0G1596863
Encoding: 0011775
Operating number: WSC 31414 790 00001
VCID: 2C5168908C90575EF2-515A
3 error codes found:
005660 - Spark plug, cylinder 3 (Q12)
P161C - 001 - Interruption.
Environmental conditions:
Error status: 01110001
Error priority: 0
Error frequency: 1.
Lost Count: 255
Mileage: 180,760 km
Time: 0.
Date: 2016.09.02
Time: 14:30:15
Speed: 798 RPM
Torque: 85.8 Nm
Speed: 0.0 km/h
Key ratio: 1.0%
Voltage: 13.98 V
Key press ratio: 24.9%
Temperature: 18.0°C
009300 - Diesel particulate filter differential pressure sensor.
P2454 - 001 - Short circuit to ground - Intermittent.
Error status: 00100001
Error priority: 0
Error frequency: 8
Lost Count: 255
Mileage: 181,782 km
Time: 0.
Date: 2016.10.30
Time: 16:29:53
Speed: 2016 /min
Torque: 214.5 Nm
Speed: 34.7 km/h
Temperature: 893.2°C
Temperature: 236.0°C
(no unit): 0.0
Pressure: 0.0 mbar.
008194 - Particle filter, bank 1.
P2002 - 001 - Malfunction - Intermittent.
Error status: 00110001
Error priority: 0
Error frequency: 3
Lost Count: 255
Mileage: 182,423 km
Time: 0.
Date: 2016.11.20
Time: 09:38:08
Speed: 2289 RPM.
(no unit): 573.4
Pressure: 0 mbar.
(no unit): 0.0
Temperature: 218.3°C
Pressure: 0.0 mbar.
Temperature: 2.7°C
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: DRV\09D-927-750.lbl
Part number SW: 09D 927 750 FA, Hardware number: 09D 927 750 FA.
Component: AL 750 6A 0992
Revision: 00H61000 Serial number:
Coding: 0004456
VCID: 72EDB6E86E3441AE78-515A
No error codes found.
Address 03: Brake Electronics
Label file: 7L0-907-379-MK25E1.clb
Part number SW: 7L0 907 379 K, Part number HW: 7L0 907 379 K.
Part: ESP ALL-WHEEL DRIVE MK25E1 0302
Revision: 00H53001
Encoding: 0006530
VCID: 418F29241C12AA3631-8014
Address 05: Access/Startup. Label file: DRV\3D0-909-13x-05.lbl
Part number SW: 3D0 909 139 B, HW: 5WK 485 04.
Component: Kessy 6840
Revision: 68406418 Serial number: VWX3Z0G1596863
Encoding: 0000232
VCID: 2859948098687B7E16-515A
Subsystem 1 - Part number: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Front Seat Adjustment
Label file: None
Part number: 7L0 959 760.
Component: Seat adjustment 0701
Operating Number: WSC 00000 000 00000
VCID: 77FB87FC025624864F-8022
Address 08: Climate Control/Heating. Label file: DRV\7L6-907-040.clb.
Part number: 7L6 907 040 AE
Component: CLIMAtronic R/L 4326
Encoding: 0000030
VCID: 73E3B3EC162E48A673-8026
Address: 09: Central Electronics
Label file: DRV\7Lx-937-049-V2.clb
Part number SW: 7L6 937 049 AF, HW: 7L6 937 049 AF.
Component: J519 2000
Revision: -0004--- Serial number: --------------
Encoding: 600004003B221C000000000000000000
VCID: 0009EC205798633E7E-8054
Address 13: Distance Control. Label file: None.
Part number SW: 7L6 907 567. Part number HW: 7L6 907 567.
Component: AC201 RDW 1 030 0363
Revision: 00030000 Serial Number: 00000000009715
Encoding: 0010000
VCID: 7BF39BCC3E7E00E62B-802E
Address 15: Airbag
Label file: 7L0-959-655.lbl
Part number SW: 7L0 959 655 HW: 7L0 959 655
Part: J234 37 VW8T 0250
Revision: 92011025 Serial Number: 0039P001B1NU
Encoding: 0013111
VCID: 7AFD9EC8314439EE30-802E
Address 16: Steering wheel electronics
Label file: DRV\7L6-953-549.lbl
Part number: 7L6 953 549 G
Component: Steering column module 3501.
Encoding: 0011022
VCID: 4383232C060EB82623-8016
Address 17: Control panel module
Label file: DRV\7L6-920-xxx-7L6.lbl
Part number SW: 7L6 920 890 KX. Part number HW: 7L6 920 890 KX.
Component: J285 COMBINATION INSTALLATION. 9833.
Revision: KHH06V45
Encoding: 0005101
Operating number: WSC 62922 000 104857
VCID: 1839A4402B08CBFEA6-804C
Address 18: Auxiliary heater
Label file: DRV\7L6-819-008.lbl
Part number: 7L6 815 071 G
Component: Standheizung E1MAC 0425.
Encoding: 0000000
VCID: 36654AF841DC1D8E94-8062
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-7L.clb
Part number SW: 6N0 909 901, HW: 7L6 920 890 KX.
Component: J533 GW-K-CAN TP20 9833
Encoding: FFE6EF9FC8056002
VCID: 70E9BCE0633873BE8E-8024
Address 22: All-wheel drive
Label file: DRV\0AD-927-755.lbl
Part number: 0AD 927 755 BE
Component: TRANSFER CASE 0119
VCID: 7F0B6FDC2D661CC607-5178
Address 34: Level Control
Label file: DRV\7Lx-907-553-34.clb
Part number: 7L0 907 553 G
Component: AIR FILTER - CDC - 3C3P1 3112
Encoding: 0015521
VCID: 377B47FC42D6E4868F-8062
Address 36: Seat adjustment for driver. Label file: None.
Component: Seat adjustment 0703
Address 37: Navigation
Label file: DRV\7L6-919-887-DVD.lbl
Part number: 7L6 919 887 P
Component: Navigation 0013
Encoding: 0000101
VCID: 53A3136CF26E28A693-8006
Address 3C: Lane Change
Label file: DRV\7E0-907-566-V1.clb
Part number SW: 7L6 907 566 B, HW: 7L6 907 566 A.
Component: J0769_SWA_MasterH08 0040
Revision: 00H08000 Serial Number: 6PZ 009 014-01
Encoding: 0010151
VCID: 3C7158D07BF0C7DE62-8068
Subsystem 1 - Part number: 7L6 907 568 B
Component: J0770_SWA_Slave_H07 0040
Subsystem 2 - Serial number: 6PZ 009 014-21.
Subsystem 3 - Serial Number: 3F08.02.0700H0700000010013Ăż
Subsystem 4 - Serial number: 010013.
Address 46: Comfort System
Label file: 7L0-959-933.lbl
Part number: 7L6 959 933.
Component: 12 HSG 7124
Encoding: 0000085
Operating number: WSC 62922 000 1048576
VCID: 7F0B6FDC2D661CC607-4B18
Subsystem 1 - Part number: 7L0 959 701 N
Component: Door control unit FS 6302.
Subsystem 2 - Part number: 7L0 959 702 N
Component: Door control unit BF 6302.
Subsystem 3 - Part number: 7L6 959 703.
Component: Door control unit HL 0202.
Subsystem 4 - Part number: 7L6 959 704.
Component: Door control unit HR 0202.
Address 55: Headlight range control. Label file: 7L6-907-357-A.lbl
Part number SW: 7L6 907 357 A, Hardware number: 7L6 907 357 A.
Component: AFS Control Unit X014
Revision: H01 Serial Number:
Encoding: 1288195
VCID: 397F41C474C2F2F679-806C
Subsystem 1 - Part number: 7L6 941 329 B
Label file: 3D0-941-329.CLB
Component: AFS-List Module l X008
Encoding: 00000019
Subsystem 2 - Part number: 7L6 941 329 B
Component: AFS-Lst. module r X008
Encoding: 00000019
Address 56: Radio
Label file: DRV\7L6-035-186-DVD.lbl
Part number: 7L6 035 186 G
Component: Radio 0013
Coding: 0012432
VCID: 377B47FC46D6E4868F-8062
Address 68: Wiper electronics
Label file: 7L0-955-119-V2.clb
Part number: 7L6 955 119.
Part: J400__ Front Wiper 5101
Coding: 0000341
VCID: 77FB87FC065624864F-8022
Subsystem 2 - Part number: 1K0 955 559 AB. Label file: DRV\1K0-955-559-AF.CLB.
Component: RLS 290307 020 0105
Encoding: 00012325
Address 69: Trailer
Label file: DRV\7L0-907-383-1D2.lbl
Part number SW: 7L0 907 383 G, Part number HW: 7L0 907 383 G.
Component: ANHAENGERELEKTRONIK 8854 (Trailer Electronics 8854)
Encoding: 0000001
VCID: 387944C04FC8EBFE86-806C
Address 6D: Rear door
Label file: DRV\7L6-959-107.clb
Part number SW: 7L6 959 107 A, Hardware: 7L6 959 107 A.
Part: J605 REAR DOOR 1210
Revision: --H05--- Serial Number: --------012444
Encoding: 0122110
Address 76: Parking Assist
Label file: Route deviation detected!
Part number: 7L0 919 283 F
Part: 0E Parking Assist System 1107.
Address 77: Phone.
unavailable
End----------------------------(Duration: 04:19)-----------------------------
Bernd.
Translated on 20-09-2026, 1:21.
Post06-01-2017, 23:40    Subject: TDI BKS Engine: Troubleshooting Electronic Issues Quote
The glow plug is likely defective given the mileage (so it's probably not a connector, cable, or fuse issue). The other errors are probably secondary issues caused by the intermittently malfunctioning differential pressure sensor on the DPF.
The latter could also be defective given the mileage, and any cable/connector issues or damage caused by rodents should be checked before replacement.
arthur
Post07-01-2017, 18:40    Subject: TDI BKS Engine: Troubleshooting Electronic Issues Quote
Thank you, Rainer.
Today, the warning light came on again, and the car went into emergency mode. Unfortunately, this happened on the highway.
Notlauf geht bis 80 Km/h im 5. Full throttle.
I'll take care of that on Monday.
Bernd.
Translated on 20-09-2026, 1:22.
arthur
Post14-01-2017, 11:20    Subject: TDI BKS Engine: Troubleshooting Electronic Issues Quote
Hello Rainer,
Everything is back to normal.
Spark plug and differential pressure sensor replaced.
340€ for everything.
I think that's okay.
Thank you and best regards.
Bernd (also known as Arthur)
Translated on 20-09-2026, 1:23.
Post14-01-2017, 11:30    Subject: TDI BKS Engine: Troubleshooting Electronic Issues Quote
Hopefully, all the glow plugs were replaced? Because the other glow plugs will likely need to be replaced soon as well.
Background information can be found in my article and the Gremlin's technical article on spark plugs.
Translated on 20-09-2026, 1:24.
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motor Electronics Failure Due to Heat Diesel Engine Technology
No new posts AGR errors On-Board Diagnostics (OBD)
No new posts 3C0-937-049-30-H Error: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts G71 Error: Troubleshooting & Solutions Diesel Engine Technology
