T4 TDI Automatic Control Unit Error 01316 Brake Communication
diepest
Post19-01-2017, 17:01    Subject: T4 TDI Automatic Control Unit Error 01316 Brake Communication Quote
I have a VW T4 bus with a engine and an automatic transmission.
In the control unit of the automatic transmission, error 01316 - Brake Control Unit 49-10 - No Communication - Sporadically is always set after engine start and pressing the brake pedal (see log).
In the measurement block 125, Motor 1, ABS l. 0 and switch box 0 are displayed, while in the instrument panel, Motor 1 and Gear 1 are displayed, and the brake field is empty.
In normalem Betrieb hat dies keine Auswirkungen. Das Getriebe schaltet einwandfrei, der Schieber wird durch den Bremspedal freigegeben, und das Getriebe wechselt beim Anhalten automatisch in den Leerlauf.
What could it be?
Best regards, Till
Post20-01-2017, 13:09    Subject: T4 TDI Automatic Control Unit Error 01316 Brake Communication Quote
Hello Till,
I would proceed as follows:
- Does the brake pedal switch operate smoothly? Is the brake pressure in the ABS/ESP system plausible?
- Battery ok? (possibly excessive voltage drops during the starting process)
- Software/Hardware fault in the ABS/ESP or automatic transmission control unit? Are there similar known errors on the web, and what are the software versions/part numbers of the involved control units?
Best regards, Rainer
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 776 No communication Diesel Engine Technology
No new posts 2.8L V6 AAH - No communication On-Board Diagnostics (OBD)
No new posts Ibiza: Communication with IT Department Diesel Engine Technology
No new posts No communication with the steering column electronics Electrical Systems, Vehicle Electronics, Multimedia
