Print Error P1297 & P1093: Troubleshooting Guide
Post26-01-2017, 18:50    Subject: Print Error P1297 & P1093: Troubleshooting Guide Quote
My Polo with the EA113 (CDL) engine is starting to show some problems at just 12,000 km.
After a few days of inactivity and a cold start at approximately -4°C engine temperature, the idle speed initially fluctuated significantly between about 800 and 1400 rpm. Starting was almost normal, but there were occasional hard jolts below 1500 rpm. Even after a few minutes of driving, the idle speed was still not stable and continued to fluctuate (though slightly less intensely than immediately after starting).
Eventually, when the engine was warm, all the problems disappeared. Even full-throttle data logs, reaching the rev limiter, appeared completely normal.
Only in the file system.
Code:
2 Fehlercodes gefunden:
004759 - Verbindung Lader-Drosselklappe
P1297 - 001 - Druckabfall
Umgebungsbedingungen:
Fehlerstatus: 01100001
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Verlernzähler: 255
Kilometerstand: 12564 km
Zeitangabe: 0
Datum: 2039.14.00
Zeit: 11:16:02
Drehzahl: 1445 /min
Last: 30.6 %
Geschwindigkeit: 31.0 km/h
Temperatur: 9.0°C
Temperatur: -3.0°C
Druck: 990.0 mbar
Spannung: 14.605 V
004243 - Bank 1; Kraftstoffbemessungssystem 2
P1093 - 008 - Fehlfunktion - Sporadisch
Fehlerstatus: 00101000
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Verlernzähler: 255
Kilometerstand: 12569 km
Zeitangabe: 0
Datum: 2039.14.00
Zeit: 11:21:23
Drehzahl: 1492 /min
Last: 27.0 %
Geschwindigkeit: 40.0 km/h
Temperatur: 53.0°C
Temperatur: -5.0°C
Druck: 1000.0 mbar
Spannung: 14.732 V
The next cold start the following morning, with a temperature of around -3°C, was also normal.
Does anyone here know the symptoms and possible causes?
Here's something else that I don't like as much:
After cold starts in winter, the engine gradually becomes "audibly rougher" under load compared to before, meaning that one cylinder produces a soft "thumping" sound during acceleration. I notice it most clearly in lower gears between 1500 and 2000 rpm. The noise completely disappears when coasting, and as the engine temperature increases, it becomes quieter and eventually vanishes altogether.
The engine doesn't misfire and otherwise runs normally and without any noticeable issues, except for the one incident mentioned above.
Oil consumption is present (approximately 0.2 liters per 1000 km), but in my opinion, it's not yet a cause for concern.
What could be the cause of the acoustic imbalance in the cylinders, which, as mentioned before, wasn't so noticeable earlier? Could it be that a connecting rod bearing or piston pin is already starting to fail? Or is it more likely a piston tilt that is correcting itself as all components reach their normal operating dimensions when warm?
Translated on 11-08-2026, 2:22.
Blackfrosch
dieselschrauber likes this.
Post26-01-2017, 19:00    Subject: Print Error P1297 & P1093: Troubleshooting Guide Quote
Cause:
Positive Crankcase Ventilation (PCV) valve - That's how it usually starts - Eventually, the engine won't run smoothly anymore, even when warm.
Translated on 11-08-2026, 2:25.
Post26-01-2017, 19:07    Subject: Print Error P1297 & P1093: Troubleshooting Guide Quote
@BlackfroschViewing profile: Blackfrosch
"Are you referring to the unusual stuttering and lag that we've seen so far?"
Or the uneven cold start noise under load?
Translated on 11-08-2026, 2:26.
Blackfrosch
Post26-01-2017, 21:31    Subject: Print Error P1297 & P1093: Troubleshooting Guide Quote
The speed fluctuations and the two error entries.
No new posts TIP: DQ400 - P0867 Function limitation due to pressure drop Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Variable valve timing malfunction General Tips
No new posts P2101 - Throttle Control Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sticking Clutch: Causes & Solutions Diesel Engine Technology
No new posts AFN Power Loss: Troubleshooting & Common Causes Diesel Engine Technology
No new posts Short Circuit Diagnosis: Intermittent Faults 01202 On-Board Diagnostics (OBD)
No new posts Cooling water leak: Why it stops and starts? Diesel Engine Technology
