ABS Failure: No MStrg Access, Other Issues
mhernach
Post13-10-2003, 16:21    Subject: ABS Failure: No MStrg Access, Other Issues Quote
HELP...
I can no longer access my engine control unit. The ABS, combination instrument, etc., are not working.
What can one do...?
Mike
PS: Ford icon_twisted.gif Galaxy 1.9 TDI, manufactured in 10/96, with a 1Z engine.
Translated on 10-10-2026, 21:47.
mhernach
Post13-10-2003, 18:49    Subject: ABS Failure: No Access to MStrg Quote
Hello again...
After the anger and the blows icon_twisted.gif on the dashboard, it works again. icon_question.gif Now I'm really wondering if I should buy a different car, or maybe even drive a Porsche on the sidewalk. icon_biggrin.gif
Have you ever experienced anything like this before?
Best regards, Mike.
Translated on 10-10-2026, 21:48.
mhernach
Post15-10-2003, 10:28    Subject: ABS Failure: No Access to MStrg Quote
..... grrr.....
I'm about to drive this car into the river.
After several attempts, I can sometimes access the control unit (STG), but then I can't anymore.
Has anyone experienced something similar? My VW dealer said the control unit (STG) is defective and needs to be replaced, but quickly, before the car breaks down?!
Best regards, Mike.
Translated on 10-10-2026, 21:49.
Post15-10-2003, 11:13    Subject: ABS Failure: No MStrg Access, Other Issues Quote
Hi Mike,
A few weeks ago, someone here already reported contact problems with the diagnostic connectors. You might be experiencing a similar issue.
Translated on 10-10-2026, 21:50.
mhernach
Post15-10-2003, 11:22    Subject: ABS Failure: No MStrg Access, Other Issues Quote
No... I can rule that out, because all the other control units are working fine (ABS, airbag, etc.), only the engine control unit is malfunctioning.
The error occurred for the first time when liquid spilled onto my OBD interface, which then malfunctioned. Coincidentally, I was just inside the engine control unit at the time, performing a diagnostic test.
I've repaired the interface, but now I'm having a problem...
Hi Mike,
A few weeks ago, someone here already reported contact problems with the diagnostic connectors. Perhaps you are experiencing a similar problem.
Translated on 10-10-2026, 21:51.
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Off: No More Soot? Diesel Engine Technology
No new posts V6 TDI: No Power? Troubleshooting Guide.:-( Diesel Engine Technology
No new posts No KAT? What happens then? Diesel Engine Technology
No new posts G3 AFN: No Boost Pressure After Inspection Diesel Engine Technology
