Golf 4, year 2003 - KOBD2Check - Operation failed
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
plepps
Post28-02-2017, 17:28    Subject: Golf 4, year 2003 - KOBD2Check - Operation failed Quote
I have a question. I wanted to read the diagnostic data from my wife's Volkswagen Golf 4, manufactured in 2013, today.
Bekomme mit KOBD2Check immer nur "Operation fehlgeschlagen". OS: Windows 7 Professional.
The OBD2 RKS+CAN adapter is being properly recognized, and the status LED is lit green.
The software also detects when a device is unplugged and then plugged back in.
However, when querying the data, a connection cannot be established.
Similarly, KCANMonitor and KDataScope are not working either.
Now, don't say that the box is too old; I specifically asked about that before buying it. icon_sad.gif
Greetings.
Tom.
Translated on 17-07-2026, 17:54.
Post28-02-2017, 18:22    Subject: Golf 4, year 2003 - KOBD2Check - Operation failed Quote
Hello Tom,
"I am quoting from the product description:"
For the OBD2 diagnosis of passenger cars from 2008 onwards
The Gold 4 doesn't even have CAN on the diagnostic interface. icon_rolleyes.gif A Golf 4 was produced in 2008, but not much later, and a production year of 2013 is unlikely unless your second name is Marty McFly.
Und nachgefragt, ob es für nen Golf 4 passt und eine Empfehlung von mir dafür zu bekommen, da geht die Wahrscheinlichkeit gegen 0%. WWhat is this email about?
KDataScope can of course be used independently of the car; the program itself works perfectly. However, you won't be able to record any data with a Golf 4 using the CAN bus interface.
KCANMonitor is not included as a separate item in your KOBD2Check order; the program is simply copied to the hard drive as part of the same installation package.
For a Volkswagen Golf 4, the correct part would be:
https://shop.dieselschrauber.org/en/vcds-hex-v2-p-329.php
Translated on 17-07-2026, 17:56.
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2003, Hands-free device malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2003, noises from the front of the car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V 1.4 Gasoline GRA retrofit failed Electrical Systems, Vehicle Electronics, Multimedia
No new posts Operation 5 -> 6 Gang Transmission, Chassis, Body & Interior
No new posts OBD2 Check: No Connection to VW T5 Multivan? On-Board Diagnostics (OBD)
No new posts KOBD2Check per Inet STGCheck permanente PW Abfrage On-Board Diagnostics (OBD)
