Passat 3B Airbag Error Deletion Login
gross.rene
Post28-02-2017, 16:26    Subject: Passat 3B Airbag Error Deletion Login Quote
Hey everyone,
I have a Passat here, from 1997. Due to a short circuit, there are errors in the memory. I would like to clear these errors, but the control unit doesn't allow it. I probably need the login for the installed control unit?
Unfortunately, VCDS doesn't display the code when I hover the mouse over the field.
Unfortunately, I can't upload a scan right now because I'm not at home. Can you still help me?
Rene.
 File size:  5.57 MB
 Viewed:  4033 times
Translated on 09-07-2026, 4:34.
Post28-02-2017, 18:33    Subject: Passat 3B Airbag Error Deletion Login Quote
Hi Rene,
No login is required to clear the error. Either the error still exists, or it is a non-erasable error (e.g., airbag deployment).
DieselBär30x
Avatar-DieselBär30x
Post28-02-2017, 21:50    Subject: Passat 3B Airbag Error Deletion Login Quote
Hello everyone!
@grossER: As always and as consistently requested in this forum, please first provide the Autoscan results as an attachment.
As Rainer already mentioned, in addition to triggering errors, there are other errors that cannot and should not be deleted.
The aforementioned Autoscan saves us the trouble of peering into a crystal ball towards the moon and further into the sky. icon_wink.gif
Best regards from Munich!
Translated on 09-07-2026, 4:35.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Fehler 65535 im Airbag STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Fehler 65535 im Airbag STG, bis 8LYA078299 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kombiinstrument (Kann Fehler nicht lĂśschen) Diesel Engine Technology
No new posts Fix Board Network Errors: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Fix Error Codes: Troubleshooting ECU Issues On-Board Diagnostics (OBD)
No new posts It is impossible to clear the error code for the V71 serv... Dieselschrauber Bar
