Polo 9N3: Getriebe verliert Öl | Posts 16+
Go to page: Previous  1, 2
stolley
Karma: +38 / -1   Thank you, like it!
Post21-03-2017, 8:11    Subject: Quote
The supposed transmission fluid is also suspiciously light...! The annoying thing about fluids is that they sometimes find an inexplicable path and then only appear somewhere else...! icon_confused.gif
The seal on the tandem pump is new, possibly I didn't tighten the screws enough... it's also really difficult to access those parts...!
On the other hand, there's some moisture on the underside of the fuel line connected to the pump. I'm going to replace the hose and clamp.
Thank you for your support!
Translated on 03-09-2026, 19:36.
Post21-03-2017, 9:16    Subject: Quote
The annoying thing about liquids is that they sometimes find an inexplicable path and then only appear somewhere completely different...
...first into the gearbox housing, ignoring the opening at the bottom, and then upwards through the threaded fitting...
Translated on 03-09-2026, 19:37.
Karma: +645 / -0   Thank you, like it!
Post21-03-2017, 11:03    Subject: Quote
Simply smell the fluids; diesel and transmission oil have a distinct odor that is unmistakable.
stolley
dieselschrauber likes this.
Post21-03-2017, 12:54    Subject: Quote
 File size:  1.67 MB
 Viewed:  596 times
Translated on 03-09-2026, 19:38.
stolley
Post21-03-2017, 18:29    Subject: Quote
Okay, I'm going to replace both fuel hoses, including the clamps, and then I'll let you know how it goes!
stolley
Post29-03-2017, 10:28    Subject: Quote
Hello everyone,
a brief update:
After installing the temperature sensor with new fuel lines and new clamps, everything is sealed again!
So quickly you can seal a transmission! icon_smile_thumb_up.gif icon_rolleyes.gif
Thank you all for your help!
Post29-03-2017, 10:32    Subject: Quote
Thank you for your feedback!
Translated on 03-09-2026, 19:39.
No new posts Doku Polo MJ 2002, Gearbox noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Automatic transmission error. Gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 Doku: Dimming Display Issue (1998-2000) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 6n2 TDI: Gearbox, Transmission, Replacement Diesel Engine Technology
No new posts Polo 6N1 Gearbox DKE Transmission, Chassis, Body & Interior
No new posts Polo diesel with a gasoline transmission??? Diesel Engine Technology
No new posts R Gear Problem: Polo AKU Transmission Compatibility Diesel Engine Technology
