Calculate Fuel Consumption
blackblizzard
Post07-01-2008, 12:15    Subject: Calculate Fuel Consumption Quote
Hello.
Since I don't have MFA (Multifunction Display), I would like to know how to calculate the fuel consumption (in liters/100km) using VAG-COM on my car.
In the MWB 15, it is only specified in liters per hour or milligrams per cycle.
Translated on 22-09-2026, 22:25.
Post07-01-2008, 12:46    Subject: Calculate Fuel Consumption Quote
Log measurement blocks 6 and 15 from the engine control unit, then import them into OpenOffice.
Consumption in liters / 100km = Liters / hour * (100 / Speed in km/h)
Translated on 22-09-2026, 22:26.
blackblizzard
Post09-01-2008, 16:43    Subject: Calculate Fuel Consumption Quote
Hello.
Sure, here's the translation:
"Thanks in advance. But is there a program that can read the speed and fuel injection amount and calculate the fuel consumption based on that?"
Translated on 22-09-2026, 22:27.
Post09-01-2008, 19:34    Subject: Calculate Fuel Consumption Quote
Here it is:
Save the 'Plugins' configuration in the VAG-COM/VCDS RKS distribution. Then, select measurement blocks 6 & 15 in the engine control unit for a TDI engine, and click on 'Plugins' -> 'KFuel'.
Does anyone need this?
 KFuel mit VCDS - Kraftstoffverbrauch per Diagnose messen
 File size:  104.42 KB
 Viewed:  15421 times
Translated on 22-09-2026, 22:28.
Post25-05-2008, 18:42    Subject: Calculate Fuel Consumption Quote
Updated KFuel now displays real-time fuel consumption, average fuel consumption, fuel used, and distance traveled.
KFuel is now part of the VCDS-RKS distribution.
wernernue
Post01-04-2017, 22:50    Subject: kfuel in VCDS 16.8.4 Quote
Hello everyone,
Is the kfuel feature no longer available in the current VCDS version (16.8.4)?
On version 15, I still have a "plugin" folder containing kfuel, but I can't find anything related to it in the interface under the measurement blocks.
Translated on 22-09-2026, 22:29.
Post02-04-2017, 9:14    Subject: Calculate Fuel Consumption Quote
KFuel is based on a different plugin interface. Because the VCDS installation package is not created by me, but by Ross-Tech, and this creates a constant source of dependencies, leading to time consumption and undesirable issues, things have been strictly separated.
That's why KPower and KDataScope now exist as separate setups.
If you have an older installation, you can replace the VCScope file in the VCDS installation directory with the one from the older installation (note that this is not actually VCScope, but rather implements the API it uses), along with the plugin folder, and replace the rest with the new files in a current installation.
If you'd like to test something specific with KFuel, that's fine, but I wouldn't want that for every update. And most current cars already have the functions that KFuel offers built into their onboard computer (FIS).
Translated on 22-09-2026, 22:30.
wernernue
Post02-04-2017, 15:39    Subject: Kfuel Quote
Hello Rainer,
Thank you for the response.
Okay, I'll go ahead and install an old VCScope. I want to check if my custom-built onboard computer in the Polo 9n is correctly measuring the values.
Best regards from Nuremberg.
Werner.
Translated on 22-09-2026, 22:32.
Post02-04-2017, 17:27    Subject: Calculate Fuel Consumption Quote
I've highlighted the following files/folders to be copied from an old VCDS installation.
 File size:  55.76 KB
 Viewed:  1654 times
VCDS-Plugins-old.rar
 VCDS-Plugins Dateien (alt)
 File name:  VCDS-Plugins-old.rar
 File size:  1.01 MB
 Downloaded:  232 times
wernernue
Post14-04-2017, 19:31    Subject: kfuel in VCDS 16.8.4 Quote
Hello Rainer,
Everything worked out. I'll keep the old version on my laptop.
Translated on 22-09-2026, 22:33.
Post17-04-2017, 16:12    Subject: Calculate Fuel Consumption Quote
No new posts High consumption General Tips
No new posts 1.4 TSI CTHA - Fuel consumption figures Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gas dynamics: How to calculate the pressure distribution ... Gasoline Engine Technology
No new posts WBX SS Consumption: Data & Analysis Gasoline Engine Technology
No new posts Unusual consumption Diesel Engine Technology
No new posts Question about consumption Diesel Engine Technology
