Passat 3C (2007): ELV & Engine Problems
Post25-04-2017, 21:25    Subject: Passat 3C (2007): ELV & Engine Problems Quote
Hi everyone,
My brother is having a problem with his Passat; sometimes the car doesn't want to start.
Symptoms: The engine runs for 1 second and then shuts off. The MFA (Multi-Function Display) shows an error message: "Engine malfunction."
Immediate restart: The engine is cranking, but not firing.
Wait 5 seconds: The engine starts smoothly.
Display error codes.
A) sometimes nothing.
B) Sometimes, the ELV (Extra Low Voltage) system is defective, resulting in an implausible signal and a short circuit to ground, but the motor itself is not faulty.
C) Sometimes the motor is locked, and there is a low voltage (ELV) fault (without any other ELV errors).
Complete error logs are attached.
Am I correct in assuming that he needs a new ELV?
Is the error pattern related to the defective microswitches described here: http://www.meinpassat.de/wiki/51.html?
Is it true, as Robin writes here, that the ELV STG (Electronic Locking Valve Steering Column) can be replaced individually for all model years, and that the comfort STG (Steering Column) does not need to be replaced at the same time?
http://www.passatforum.com/forum/viewtopic.php?f=30&t=27008
Two years later, it was claimed that the KSG (a specific component or system) sometimes needed to be replaced.
http://www.motor-talk.de/forum/lenkrad-verriegelung-defekt-t4773854.html?page=4
Thank you for the clarification, and best regards.
Guste.
Motor+ELV.txt
 File name:  Motor+ELV.txt
 File size:  15.51 KB
 Downloaded:  572 times
nur_ELV.txt
 File name:  nur_ELV.txt
 File size:  15.89 KB
 Downloaded:  1177 times
Translated on 03-10-2026, 19:38.
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance Issues, Error 17707, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ELV Passat B6 2007 On-Board Diagnostics (OBD)
No new posts BMW X3 2.0d: 2007 Model with AGR Seats Diesel Engine Technology
No new posts T5 Central Locking: 2007 Model for Sale Electrical Systems, Vehicle Electronics, Multimedia
No new posts Mini R56 1.6l 88kW, 2007, Variable exhaust camshaft timing Gasoline Engine Technology
