sunbeam1971 Blaumann
09-12-2011, 18:18 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
Hi!
I'm having a problem with my T4. It stalled while driving and won't start anymore. There are no error codes in the diagnostic memory. The engine runs normally as long as I spray brake cleaner into the intake manifold. The fuel tank is about three-quarters full. No fuel is reaching the injectors. Relay 109 is engaging, and I've even bypassed it with a cable. The ELAB (fuel pump relay) also engages and receives power during starting. I disconnected the blue return line, and diesel was leaking out of it when starting; it's also leaking where you screw in the measuring gauge.
Could it be that not enough pressure is being built up in the high-pressure section?
or are there also electrical faults that could prevent diesel from reaching the injectors?
Thank you in advance, and have a nice weekend.
Best regards, Heiko.
Translated on 16-08-2026, 12:58.
Profile PM Email |
mullemaus Guest
09-12-2011, 21:09 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
Is the water pump belt still installed? And is the timing belt itself also still in place?
Translated on 16-08-2026, 12:59.
09-12-2011, 21:31 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
Hey, sorry I forgot to mention, but both belts are installed.
Heiko
Profile PM Email |
09-12-2011, 22:33 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
Is the motor speed being detected?
Please also seal the drain plug first, because if it leaks from there, it's definitely not going to get any better. MfG. Michael
Translated on 16-08-2026, 13:00.
Profile PM Garage |
09-12-2011, 22:40 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
The screw is tightened and sealed again. Shouldn't there be an entry in the error memory if the speed data is missing? I mean, the tachometer shows a reading, but I'm not entirely sure.
Heiko
Profile PM Email |
09-12-2011, 22:43 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
sunbeam1971 wrote: | | The screw is tightened again and also sealed. | Shouldn't there be an entry in the error memory if the speed data is missing?  How does the control unit know whether the engine isn't actually turning, or whether the sensor simply isn't providing any information anymore?
The ACV doesn't actually have a camshaft sensor to monitor that. } MfG. Michael
Translated on 16-08-2026, 13:01.
Profile PM Garage |
09-12-2011, 22:49 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
How can I determine that?
Translated on 16-08-2026, 13:02.
Profile PM Email |
09-12-2011, 23:56 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
Choose any suitable gear  where the engine speed is appropriate, and try to start it.
The starter motor should be able to handle at least 250-300 RPM. MfG. Michael
Profile PM Garage |
09-12-2011, 23:58 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
Okay, I'll check it out tomorrow.
Profile PM Email |
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +36 / -0 Location: Wien 2001 Audi A2  Premium Support
24-05-2017, 10:16 Subject: T4 2.5 TDI ACV Engine Failure While Driving |
It's always interesting to find out what it was!
Translated on 16-08-2026, 13:03.
Profile PM Garage |
