Oil Light On? Troubleshooting & Solutions
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
soto
Post03-10-2010, 9:37    Subject: Oil Light On? Troubleshooting & Solutions Quote
Hello... I'm at a loss and urgently need help! I have an Audi A6 Quattro Avant 2.5 TDI.
(Year 2000) I bought it a few months ago and thought I had bought something "good," but since then I've only had problems! icon_sad.gif I'm seriously considering selling it again!
Okay, but now let's move on to my new problem, and hopefully someone here can help me with it!
For a few days now, the oil pressure warning light has been coming on repeatedly, even though there is enough oil. Then I stop the car, and the next day everything is okay again! icon_cry.gif
Unfortunately, I don't currently have the necessary "pocket money" to have the car checked by Audi. icon_sad.gif
WHAT COULD IT BE...? EXPENSIVE?
Dearest greetings,
Translated on 18-10-2026, 22:29.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post03-10-2010, 18:25    Subject: Oil Light On? Troubleshooting & Solutions Quote
Hello.
Let's try replacing the oil pressure switch/sensor first. It's not very expensive and it's not a big job to replace.
Good luck!
Mpire.
Translated on 18-10-2026, 22:30.
Styrian
Post04-10-2010, 15:27    Subject: Oil Light On? Troubleshooting & Solutions Quote
...I don't want to worry you right now, but please search this forum for "A6 2.5 TDI" or the engine codes "AKN" or "AKE"... you might have just bought yourself a car that's a money pit (on the contrary).
Best regards, Styrian.
Translated on 18-10-2026, 22:31.
soto
Post04-10-2010, 15:30    Subject: Oil Light On? Troubleshooting & Solutions Quote
Hello...
Yes, I've been thinking about that too, because it only lights up when the engine is properly warm!
Thank you very much!
soto
Post04-10-2010, 15:33    Subject: Oil Light On? Troubleshooting & Solutions Quote
icon_question.gif icon_question.gif icon_question.gif ...Hello Greetz, Styrian.
Translated on 18-10-2026, 22:32.
Post04-10-2010, 16:14    Subject: Oil Light On? Troubleshooting & Solutions Quote
You can easily spend a fortune on a 2.5 TDI...
It is considered relatively prone to certain issues, such as problems with the camshaft and fuel injection pump.
Before I move the car any further, I would first want to investigate the oil issue, preferably by measuring the oil pressure. The oil pressure is always lowest when the engine is warm.
Translated on 18-10-2026, 22:33.
Post05-10-2010, 6:40    Subject: Oil Light On? Troubleshooting & Solutions Quote
Also, let's also check what kind of oil is being used, or if you're unsure, switch to an approved type of oil.
Background: If oil that is currently too thin is being used, the oil pressure may also be slightly lower than normal, which could lead to these effects in a warm engine.
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 18-10-2026, 22:34.
Karma: +1349 / -0   Thank you, like it!
Post05-10-2010, 18:03    Subject: Oil Light On? Troubleshooting & Solutions Quote
The A6 2.5 TDI should also have a dynamic oil pressure control system (?).
When does the oil level warning light come on, even when idling, or only at a medium engine speed? In the latter case, the warning buzzer might also activate (which may be different in the A6).
"vg" is an abbreviation for "very good". It is often used in online forums and chat rooms to express agreement or approval.
Translated on 18-10-2026, 22:35.
Post05-10-2010, 21:56    Subject: Oil Light On? Troubleshooting & Solutions Quote
It is known that the connectors on the oil pressure switch may not be making 100% contact, and bending them can often help.
Paule0123
Post12-10-2010, 15:47    Subject: Oil Light On? Troubleshooting & Solutions Quote
Hello Soto, I had the same problem with my A4 2.5 TDI.
After I replaced the oil pressure switch and sensor, the oil pressure indicator still lit up.
It keeps coming back on. There's a ground point located in the engine compartment, on the front left side, underneath the headlight. It's a bit difficult to reach.
Clean the contacts and cable terminals (which may be oxidized). In my case, a ground cable was even broken, which I replaced. And don't be stingy with contact cleaner. I haven't had any problems since then (about 2000 km).
Translated on 18-10-2026, 22:36.
Hannes
Post24-05-2017, 9:31    Subject: Oil Light On? Troubleshooting & Solutions Quote
I'm experiencing the same problem with the oil pressure sensor in my A6 (engine: BAU). My question is, where is this sensor located?
Hannes.
Audi Allroad quattro LR, 2004
Audi S6 Avant quattro, 1995
Translated on 18-10-2026, 22:37.
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia Starting Problems: ESP Repair Not the Issue? Diesel Engine Technology
No new posts Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Diesel Engine Technology
No new posts Flashing light bulb, even though everything seems to be w... Diesel Engine Technology
No new posts Oil Change: Regular Oil Instead of Synthetic? Diesel Engine Technology
