Methylalkohol im Diesel? | Posts 16+
Go to page: Previous  1, 2
eike
Post17-10-2003, 17:48    Subject: Quote
Injecting fuel into the intake manifold, I think, is less than ideal. Either the fuel will vaporize prematurely, or it will ignite (due to high octane fuel and a large ignition delay!) quite abruptly in the cylinder, leading to knocking... (diesel engines require a smaller ignition delay).
CU Gremlin
Take a look at the topics related to water injection. It is often written that the best effects are achieved using a water-alcohol mixture.
If the concentration is around 60%, it should be perfectly suitable.
Greetings.
Eike.
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel 2.0 170 HP: Specs & Performance Diesel Engine Technology
No new posts LD Log A3 8P 2.0 CR Diesel Upload
No new posts Diesel Engine Oil Diesel Engine Technology
No new posts 2-Stroke Diesel Engines: The Sequel Diesel Engine Technology
