odU
21-07-2017, 9:54 Subject: Bosch VP37 Injection Pump Head |
Hello.
I have a question.
wo bekomme Ich die Dichtung für den Pumpenkopf einer Bosch VP 37 ev. E-NR
It can't be right that you can only get this sealing ring from Bosch.
With the correct dimensions, it should also be available from the manufacturer of the seals (I only need the seal itself, but I don't have the dimensions).
Bosch part number: pump 0460 404 971 R 510-3 BT 4015.
Audi No: 028 130 115 W
The vehicle is an Audi A4 B5 1.9 TDI, 90 kW, manufactured in 1998, with engine code AHU.
Thank you in advance for your reply.
Translated on 14-10-2026, 3:12.
jarobaldu Profi-Schrauber
21-07-2017, 10:14 Subject: Bosch VP37 Injection Pump Head |
"You can find this type of gasket at Bosch for about 15 euros."
What's the problem? You might as well replace the other seals while you're at it.
Adrian. Renault Espace 16V Bj. 2000 mit LPG
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 14-10-2026, 3:14.
odU
21-07-2017, 10:56 Subject: Bosch VP37 Injection Pump Head |
Okay, I understand. I just want to seal the pump head; the rest is still sealed. And it doesn't make sense to throw away the remaining seals.
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
Rüdi likes this. |
21-07-2017, 11:07 Subject: Bosch VP37 Injection Pump Head |
Then, just keep the rest as a reserve, in case something else starts leaking. Touran 5T1 / DFGA / TGV; Fabia 6Y5 / BNV / GGV
Translated on 14-10-2026, 3:15.
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
21-07-2017, 22:00 Subject: Bosch VP37 Injection Pump Head |
Hello.
The large O-ring for the pump head measures 59x2.5mm.
A single piece of seamless NBR rubber costs approximately 3 euros.
It is resistant to the bio component in diesel when made from Viton (FPM/FKM).
Then it will be about 50 cents more expensive.
Just ask around in the industrial supplies/hydraulic service/agricultural machinery sector  .
Mpire fehlen Dir die Worte, entscheiden die Taten!
Profile PM Garage |
odU
22-07-2017, 10:24 Subject: SEO: Best Practices for Ranking Higher on Google |
Okay, that's what I wanted to know before I remove the old ring!!
I assume that the 59 mm is the outer dimension and the 2.5 is the cord diameter.
I'm going to buy some now, possibly silicone ones.
Thank you and best regards.
Translated on 14-10-2026, 3:16.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
22-07-2017, 12:58 Subject: Bosch VP37 Injection Pump Head |
odU wrote: | | I'm going to get some now, possibly made of silicone | .
https://www.ludwigmeister.de/technische-informationen/dichtungstechnik wrote: | | Generally, silicone is not resistant to fuels, aromatic mineral oils, water vapor (short-term exposure up to 120°C is possible), silicone oils and greases, acids, and alkalis. |
Translated on 14-10-2026, 3:17.
Profile PM WWW Garage |
odU
22-07-2017, 16:46 Subject: SEO: Best Practices for Ranking Higher on Google |
Okay, I'll try to find a suitable one.
"Thank you."
Translated on 14-10-2026, 3:18.
Herbert Profi-Schrauber
24-07-2017, 11:17 Subject: Bosch VP37 Injection Pump Head |
Quote: | | I assume that the 59 mm is the outer dimension and the 2.5 is the cord diameter. |
You should take another, closer look at that.
Herbert. Horch A4 8K CJCD
odU
24-07-2017, 14:47 Subject: Bosch VP37 Injection Pump Head |
Yes, as I understand it now, the 59 mm is the internal dimension.
I haven't been able to find a suitable sealing ring yet.
But it's not urgent yet; it's still running.
If I order one, it will also have a delivery time.
I'll probably stop by the agricultural machinery mechanic's shop sometime.
Thank you again.
Translated on 14-10-2026, 3:19.
24-07-2017, 20:16 Subject: Bosch VP37 Injection Pump Head |
Sure, here's the translation:
"Just for information:"
In the field of fluid technology, O-rings are always specified with their inner diameter x cross-section thickness.
surveyed.
Exceptions to this rule are only specially molded seals or profile rings.
which then always receive the specified size at the point of sale.
Just type "ring 59 x 2 5" into the online marketplace  and you will find many options.
Translated on 14-10-2026, 3:20.
Profile PM Garage |
odU
24-07-2017, 22:28 Subject: Bosch VP37 Injection Pump Head |
Okay.
Thank you all again for your help!
Translated on 14-10-2026, 3:21.
