Reparatur Schwellerspitze Golf 3 | Posts 16+
Go to page: Previous  1, 2
bindpe
Karma: +5 / -2   Thank you, like it!
Post07-09-2017, 10:03    Subject: Quote
Hello.
What should I do with the areas where I can't properly remove the rust?
 File size:  5.18 MB
 Viewed:  450 times
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 22-09-2026, 6:51.
vag-driver
Post07-09-2017, 10:44    Subject: Quote
bindpe wrote:
Hello.
You should treat it with Owatrol. I don't see any other way. Unless you completely strip the paint from the entire vehicle.
Andreas
bindpe
Post07-09-2017, 12:01    Subject: Quote
Thank you for the tip.
Unfortunately, stripping the paint is not an option, as I want to keep the car for as long as possible.
Spritmonitor.de
Translated on 22-09-2026, 6:52.
vag-driver
Post07-09-2017, 12:19    Subject: Quote
That's why Owatrol. It penetrates cracks and damage in existing underbody coatings, allowing it to reach and stop any potential rust. Additionally, Owatrol makes the underbody coating more flexible.
After that, finish the treatment with KLine Permanent Wax or UBS240.
Andreas
No new posts Cushion button repair General Tips
No new posts Repair of oil pump drive for 2.0 PD TDIs with balance shafts Troubleshooting & Guides
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts LMM repair Diesel Engine Technology
No new posts Repair of PD elements? Diesel Engine Technology
No new posts Repair of Zexel fuel injection pump Diesel Engine Technology
No new posts Repair of E-injector with NHG // Audi V6 TDI Diesel Engine Technology
