Code Radio "Alpha"
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
DocSnydor
Post05-03-2003, 15:58    Subject: Code Radio "Alpha" Quote
I have a problem (not yet, but I'm sure it will happen soon).
I bought a 1995 Volkswagen Golf (3rd generation) that still has the original Alpha radio installed. Unfortunately, I can't find the code for that anywhere.
The salesperson also doesn't (company car)...
Okay, the radio is working, but it definitely won't work if I disconnect the battery. Is there a way to extract the code? Or is there a key generator based on the serial number, or something like that?
Unfortunately, I only found the 'expensive' way through the Bosch service. And I didn't really want to spend money on it. You understand this because of an 'alpha,' right?icon_smile.gif
Thank you in advance for your answers...
Hello.
P.S. This might be slightly off-topic, but maybe someone here has some advice?
Translated on 05-07-2026, 10:17.
Post05-03-2003, 19:28    Subject: Code Radio "Alpha" Quote
Who is the manufacturer?
If you sell the car to a VAG dealer, they can have the code calculated from the serial number through their distribution center. The missing code didn't cause any problems for me.
Translated on 05-07-2026, 10:18.
joergs
Post05-03-2003, 20:20    Subject: Code Radio "Alpha" Quote
When I bought my Passat about 4 years ago, it was the same. The battery was disconnected, and the radio wasn't working! I went to the dealership, donated 5 Deutsche Mark to the coffee fund, and the issue was resolved in 5 minutes! They calculated the code based on the serial number. However, that was a beta version.
Translated on 05-07-2026, 10:19.
DocSnydor
Post06-03-2003, 8:38    Subject: Code Radio "Alpha" Quote
Thanks for your tips. I guess I'll have to go to the doctor then. I think that 'alpha' might be a blue dot.
Translated on 05-07-2026, 10:20.
andi
Post11-05-2003, 16:48    Subject: Code Radio "Alpha" Quote
Hello there,
Here's a VW Alpha steering wheel, red/blue, from a Golf 4. I've had it disassembled for the past 2 years, and just to let you know, it still works when I connect it to 12V. But why? Are newer radios no longer protected by software codes?
Post11-05-2003, 17:07    Subject: Code Radio "Alpha" Quote
Hi Andi,
andi wrote:
Are the newer radios no longer protected by a code???
Yes, but the radio is "locked" to the vehicle. Once the radio is reinstalled in the original car, it will work without requiring a code.
Unfortunately, I cannot tell you which radio and car combinations support these features. I am only aware of the Gamma 5- (from VDO) that is used in VW Shanghai. This function can also be disabled in production.
Translated on 05-07-2026, 10:21.
andi
Post11-05-2003, 21:49    Subject: Code Radio "Alpha" Quote
I mean, the radio works when I just plug it into a power supply. Without the car. How is the marriage verified from the control unit?
Translated on 05-07-2026, 10:22.
Post12-05-2003, 6:13    Subject: Code Radio "Alpha" Quote
Hi Andi,
andi wrote:
I mean, the radio works when I simply connect it to a power supply. Without a car.
He might not have a code (assumption).
How is the wedding verified, from the control unit?
Via the K-Bus from WFS. For those who have used VAG COM and wondered about the strange numbers displayed when reading the EDC (Electronic Data Carrier), one of them is the vehicle's VIN (Vehicle Identification Number), and another is the serial number of the radio.
Translated on 05-07-2026, 10:23.
Gremlin
Post13-05-2003, 20:13    Subject: Code Radio "Alpha" Quote
Do you happen to know where the radio code is located?
According to the user manual, the workshop can provide me with this information, in case I want to sell the radio or use it in any way without the vehicle.
in which measurement block, either in the radio or the EDC?
CU Gremlin.
Translated on 05-07-2026, 10:24.
Post13-05-2003, 21:08    Subject: Code Radio "Alpha" Quote
Hi Gremlin,
Gremlin wrote:
do you happen to know WHERE the radio code is located?
I'm afraid I have to disappoint you. The code can only be calculated from the serial number of the radio. "The customer also inquired at the VZ (likely a company or organization), because only there is a so-called 'CodeBox' available."
Translated on 05-07-2026, 10:25.
wernernue
Post13-09-2017, 17:52    Subject: Pair radio with known code to WFS Quote
Hello everyone, I have a question.
Can I program an Alpha radio with a known code into a Polo 9n's onboard diagnostics (OBD) system using VCDS?
The radio is only connected to the other control units via the K-line, not via the CAN bus.
Translated on 05-07-2026, 10:26.
Post14-09-2017, 18:50    Subject: Re: Pairing radio with known code to WFS Quote
No.
wernernue
Post14-09-2017, 21:32    Subject: Code Radio "Alpha" Quote
Thank you for the information.
However, it now works automatically because I connected pin 5 and 7 to the constant positive terminal, and pin 4 to the switched positive terminal from the ignition switch, according to the wiring diagram. Once I entered the PIN, it worked, and now it works without it. After having the radio without power for the whole day, it went into sleep mode and then immediately became unlocked.
Translated on 05-07-2026, 10:27.
Post15-09-2017, 12:18    Subject: Code Radio "Alpha" Quote
Oh yes, I forgot to mention... That was all so long ago icon_wink.gif....
After entering the code "married," the radio automatically pairs with the vehicle. The code input will no longer be required after that.
Translated on 05-07-2026, 10:28.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts "AdBlue error message, but fault memory is empty." Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
