"8V0035036G: Missing Label File? Fix Now!"
A3-Besitzer
Registered VCDS User
Post18-09-2017, 14:41    Subject: "8V0035036G: Missing Label File? Fix Now!" Quote
Unfortunately, the current VCDS version does not include the label file for MIB1/MMI-High 8V0035036G (software version "G" at the end).
Will this be implemented?
Translated on 28-09-2026, 6:05.
Post18-09-2017, 15:09    Subject: "8V0035036G: Missing Label File? Fix Now!" Quote
Please contact Ross-Tech Support directly with an Autoscan and the control unit information of the control unit that is not supported: https://shop.dieselschrauber.org/en/contact_us.php
Translated on 28-09-2026, 6:06.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. easyDIAG won't accept my log file. On-Board Diagnostics (OBD)
No new posts Passat AFN: CAN-Bus on MSG - Yes or No? On-Board Diagnostics (OBD)
No new posts WFS Login Code Missing: What to Do? On-Board Diagnostics (OBD)
No new posts Passat 3B lock between 3rd and 5th gear. Gang no longer a... Transmission, Chassis, Body & Interior
