Schmierpfote Schrauber
Joined: 07/31/2016 Posts: 93 Karma: +21 / -0 Location: Erfurt
16-09-2017, 16:46 Subject: Grey White Exhaust Smoke: Causes & Fixes |
Hello everyone in the forum,
My Passat 1.9 TDI PD with engine code AVB is experiencing excessive oil consumption again. It's smoking heavily, and even at idle, there's a lot of smoke. The engine seems to have more internal pressure than usual. When I remove the oil filler cap, white-gray smoke comes out, and a little engine oil sprays out. Hopefully, it's just another PD injector that's failing.
Please review my log.
Thank you very much, and have a nice weekend, Wolfgang.
| Description: |
 Download |
| File name: |
Log-SU-WVWZZZ3BZ2E385918-571240km.txt |
| File size: |
2.75 KB |
| Downloaded: |
1025 times |
Translated on 28-09-2026, 10:50.
Profile PM Email |
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
16-09-2017, 18:16 Subject: Grey White Exhaust Smoke: Causes & Fixes |
Hello Wolfgang,
Your log doesn't say much, except that it seems I can still drive my engine for a few more kilometers.
As you already mentioned, a problem with the glow plug could cause a leak in the combustion chamber or fuel supply within the cylinder head.
With a bit of bad luck, a cracked piston could also be possible at this mileage, but the negative fuel injection deviation reported by the idle speed control system suggests a more likely cause: a worn or leaky common rail injector element in the cylinder head.
Translated on 28-09-2026, 10:52.
Profile PM WWW Garage |
dieselschrauber likes this. |
16-09-2017, 21:34 Subject: Grey White Exhaust Smoke: Causes & Fixes |
Hello Rainer,
Thank you for the quick help. I just inspected the ZKH (presumably a component or system) and saw that three PD (presumably a type of component) housings in the ZK (presumably another component or system) have been cleaned by the escaping diesel fuel. (Photo)
I don't think the engine has a piston problem; it accelerates well and reaches its top speed. I'll replace the seals in two months, as I'm getting a Touran then, and I need to keep this car running until then.
Thank you, Rainer. Best regards, Wolfgang.
| Description: |
| File size: |
2.28 MB |
| Viewed: |
1661 times |
Translated on 28-09-2026, 10:53.
Profile PM Email |
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
18-09-2017, 6:06 Subject: Grey White Exhaust Smoke: Causes & Fixes |
It would be very interesting to see what the values look like after the procedure.
Right now, it looks like this to me:
PDE2 and PDE3 are internally blocked and mechanically damaged; PDE4 is on its way to being the same. Only PDE1 is still functioning properly.
The lean-out regulation attempts to keep the slower injectors working properly by providing them with more fuel. PDE1 roughly compensates for this amount. That's why there are such high negative values.
Passat Variant BGW 2005
Translated on 28-09-2026, 10:54.
Steffen W likes this. |
18-09-2017, 22:24 Subject: Grey White Exhaust Smoke: Causes & Fixes |
Hello Steffen W,
I have sealed all the injectors, changed the oil, and the smoke from the exhaust has disappeared. I moved the injector from cylinder 1 to cylinder 4, the injector from cylinder 2 to cylinder 4, the injector from cylinder 4 to cylinder 1, and the injector from cylinder 3 remains in its original position.
I checked the log, but it didn't work at a higher speed. I hope the Passat will last for at least another two months.
I will no longer install new Positive Displacement Elements (PDEs) in this worn-out control head. However, even when I remove the oil filler cap, there is still a lot of pressure in the engine.
| Description: |
 Download |
| File name: |
Log-SU-571290km.txt |
| File size: |
987 Bytes |
| Downloaded: |
224 times |
Translated on 28-09-2026, 10:56.
Profile PM Email |
20-09-2017, 6:18 Subject: Grey White Exhaust Smoke: Causes & Fixes |
Thank you for the values.
Since he's retiring in 2 months anyway, I wouldn't do anything else. Power equipment isn't exactly cheap. He's driving it, so just keep an eye on the oil level.
It has definitely reached a biblical mileage.
Translated on 28-09-2026, 10:57.
20-09-2017, 6:20 Subject: Grey White Exhaust Smoke: Causes & Fixes |
Schmierpfote wrote: |
I checked the log, but it didn't work at higher speeds.
Greetings Wolfgang |
If it's about MWB13, that's normal. It's an idle speed control system.
