Longlife Service Anzeige zurücksetzen klappt nicht! | Posts 16+
Go to page: Previous  1, 2
a4b82.0tdi likes this.
Post23-10-2017, 21:32    Subject: Quote
see https://community.dieselschrauber.org/en/viewtopic.php?t=3139
Translated on 29-10-2026, 10:35.
a4b82.0tdi
Post23-10-2017, 21:51    Subject: Quote
Hello Rainer,
Okay, I've already looked at that, and I was also able to set channels 53 and 55 to 0 – and they stayed that way.
However, channel 2 is changed from 1 to 0 (with "...LL Rest of the World/Diesel..."), with a message indicating that everything has been written and saved, but when the engine is turned off or on, the message "Service due!" always appears.
When I look at the MMI, I also see the 30,000 km and 730 days, but despite that, this message still appears.
I don't know what else I can do.
- Do you have any other ideas?
Thank you in advance, and best regards.
Translated on 29-10-2026, 10:36.
Post23-10-2017, 22:11    Subject: Quote
Based on what you're describing, it seems like the standard adjustment channels within the AI are being used. icon_idea.gif However, the assistant should be able to handle service restoration requests.
Please post the contents of your adaption.log file, which is located in the "Logs" subdirectory of your VCDS installation directory.
And please, perform an auto-scan.
Translated on 29-10-2026, 10:37.
a4b82.0tdi
Post24-10-2017, 20:55    Subject: Quote
I found an error on device 08, which is related to climate control/heating - that's probably the reason.
Perhaps there are also 3 errors in the "01 Engine Electronics" module?
What's the story behind these errors?
Okay, here's the translation:
Thank you.
Scan:
Tuesday, October 24, 2017, 8:57:42 PM.
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 8.1 x86.
VCDS Version: RKS 17.8.0.1
Data as of: 20170817 DS276.4
Mileage: Repair order: 2017-10-24_180240_Service record
VCDS RKS 17.8.0: Resetting the maintenance interval display.
Control unit part number: 8K0 920 900 Q
Label file: .DRV\8T0-920-xxx-17.clb
Component: COMBINATION INSTRUMENT. H20 0258, Coding: 0F04100002000008000000
Procedure: Reset flexible service interval (LongLife/Rest of the World/Gasoline engine).
Channel | Description | Unit | Current Value | New Value
02 Status Service interval display 1 0
40 Distance traveled since last inspection km x100 1 ---
41. Time since service: Day(s) 1 ---
42. Distance (minimum) to service station: km x 100. 150. 150.
43. Distance (Maximum) to Service Station: km x 100 = 300, 300.
44 Time (Maximum) until service: Days 730 730
45 ÷lquality 2 2
47 Record entry DIST x100 0 ---
48 Thermal Load DIST x100 0 ---
49. Time (minimum) until service: Days 730 365
50 Base value, distance up to speed change km x100 150 ---
51. Base value: Time until oil change: Days: 365 ---
52. Base value for distance to inspection point: km x 100 = 300. ---
53. Distance traveled since last inspection: km x100. 1. ---.
54 Base value: Time until inspection Day(s) 730 ---
55. Time since inspection: 3 days.
56 Daily counter Day(s) 2442 ---
Service disruption:
Tuesday, October 24, 2017, 20:55:31:25999
Vehicle Identification Number: xxx
License plate: xxx
Mileage: 180,240 km. Repair order: 2017-10-24_180240_Scan.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 69 72 77
Mileage: 180,240 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel Steering Electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
42-volt electric vehicle driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-inch electric auxiliary passenger seat -- Status: OK 0000
53-Parking brake -- Status: OK 0000
55-Brightness adjustment. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-High voltage electrical test. Passed. Status: OK.
69-gallon tank -- Status: OK.
72-volt electrical, high, right -- Status: OK 0000
77-Phone -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine Control Module (J623-CAGA)
Label file: .DRV\03L-906-019-CAG.clb
Part number SW: 03L 906 022 NN, Part number HW: 03L 906 019 AL.
Component: R4 2.0l TDI, H32 9980.
Revision: 25H32---
Encoding: 12194012232403080000
Operating number: WSC 43156 002 1048576
ASAM Dataset: EV_ECM20TDI03L906022NN A02016
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 7EF46DDEE192FAB6F8-802A
3 error codes found:
4695 - Function restriction due to received error value.
U1113 00 [032] - -
Sporadic - unconfirmed - checked since last deletion.
4698 - Function restriction due to received error value.
U1113 00 [032] - -
4699 - Function restriction due to received error value.
U1113 00 [032] - -
Readiness: 0 0 0 0 0
Address 03: Brake Electronics (J104)
Label file: .DRV\8K0-907-379-V1.clb
Part number SW: 8K0 907 379 BF, Hardware number: 8K0 907 379 BF.
Component: ESP8 front
H04 0030
Revision: -------- Serial Number: --------------
Encoding: 168504
Operating number: WSC 06324 123 12345
VCID: 7EF46DDEE992FAB6F8-802A
No error codes found.
Address 05: Access/Startup Authorization (J393)
Label file: .DRV\8K0-907-064-05.clb
Part number SW: 8K0 907 064 CP, Hardware: 8K0 907 064 CP.
Component: BCM2 2.0 H05 0435
Revision: 00002001
Encoding: 032200
Operating number: WSC 06325 000 00000
VCID: 0008132693668C468A-8054
Subsystem 1 - Part number SW: 8T0 959 754 D, HW: 8T0 959 754 D.
Component: FBSAUDIB8 IDG H60 0072.
Serial number: 0811000010493014
Subsystem 2 - Part number SW: 8K0 905 852 D, HW: 8K0 905 852 D.
Component: J764 ELV MLB H37 0042
Serial number: 2311000000718012
Address 08: Climate Control/Heating Module (J255)
Label file: .DRV\8Tx-820-043-1Z.clb
Part number SW: 8T1 820 043 AG, Hardware number: 8T1 820 043 AG.
Component: CLIMATE ZONE 1, Part Number H08 0180.
Revision: A0000000 Serial Number: 01070220112254
Coding: 34200000
VCID: 76E475FEC1A2B2F6A0-8022
"One error found:"
01271 - Temperature flap control motor (V68)
001 - upper limit exceeded.
Environmental conditions:
Error status: 01100001
Error priority: 3
Error frequency: 5
Lost Count: 238
Mileage: 178,366 km
Time: 0.
Date: 2017.10.16
Time: 11:32:10
Voltage: 13.00 V
Temperature: 16.0°C
Temperature: 14.0°C
Quantity: 11185
Quantity: 11915
Binary value: 01000000
Binary value: 00000111
Time: 6.00 s
Address 09: Central Electronics (J519)
Label file: .DRV\8K0-907-063.clb
Part number SW: 8K0 907 063 N, HW: 8K0 907 063 N.
Component: BCM1 1.0 H30 0392
Revision: 09030001 Serial Number: 00000000791997
Encoding: 260050914034AF000001000000001D0D001C270806010101000000
VCID: 3A7CA1CEB53A169684-806E
Subsystem 1 - Part number SW: 8K1 955 119 A, HW: 8T1 955 119, Label file: DRV\1KX-955-119.CLB.
Component: WWS 100211 H07 0070
Serial number: SWF11020106169
Encoding: 00FD11
Subsystem 2 - Part number SW: 8K0 955 559 HW: 8K0 955 559 Label file: DRV\8K0-955-559.CLB
Component: RLS H04 0003.
Serial number: 11271927
Encoding: 025028
Subsystem 3 - Part number SW: 8K0 941 531 AS, HW: 8K0 941 531 AS.
Component: E1 - LDS H03 0031.
Serial number: 00000000000102111510
Address 10: Parking Assist 2 (J446) Label file: .DRV\8K0-919-475.clb
Part number SW: 8K0 919 475 AA, HW: 8P0 919 475 N.
Part: PARKING ASSIST 8K H01 0080
Revision: 11001001 Serial number: 12501103900209
Encoding: 110203
Operating number: WSC 06325 123 12345
VCID: 78F87BC6CBB6C486B2-802C
Address 15: Airbag (J234) Label file: | DRV\8K0-959-655.clb
Part number SW: 8K0 959 655 L, Part number HW: 8K0 959 655 L.
Component: Airbag VW-AU10 H44 0610
Serial number: 003JMD093KUX
Encoding: 30513435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 4684C53EF9C26276F0-8012
Crash sensor for driver-side side airbag:
Serial number: 6334MSME3D504E09L
Crash sensor for the side airbag, passenger side.
Serial number: 6344MSME5A61677CS
Crash sensor for rear side airbag, driver's side.
Serial number: 6352QSME01083D68G
Crash sensor for rear side airbag, passenger side.
Serial number: 6362QSME600039400
Crash sensor for front airbag, driver's side:
Serial number: 63732SME5F7F331CH
Crash sensor for front passenger airbag.
Serial number: 63832SME66034246V
Adresse 16: Lenkradelektronik (J527) Labeldatei:. DRV\8K0-953-568.clb
Teilenummer SW: 8R0 953 568 J HW: 8R0 953 568 J
Bauteil: Lenks.Modul H07 0156
Revision: 00000000 Seriennummer: 20110207000414
Codierung: 000007
Betriebsnr.: WSC 06325 000 00000
VCID: 4898CB06FBD6740602-801C
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:. DRV\8T0-920-xxx-17.clb
Teilenummer SW: 8K0 920 900 Q HW: 8K0 920 900 Q
Bauteil: KOMBIINSTR. H20 0258
Revision: 00200000 Seriennummer: EJ321PC2C
Codierung: 0F04100002000008000000
VCID: 3878BBC68B36048672-806C
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\8T0-907-468.clb
Teilenummer SW: 8T0 907 468 AB HW: 8T0 907 468 H
Bauteil: GW-BEM 5CAN H06 0117
Revision: GB800053 Seriennummer: 5300G111298450
Codierung: 00CF07
VCID: 010E1622986C854E85-8054
Subsystem 1 - Teilenummer SW: 8X0 915 181 HW: 8X0 915 181
Bauteil: J367-BDM H07 0140
Seriennummer: 00000000005650535041
Subsystem 2 - Teilenummer SW: 8K0 959 663 B HW: 8K0 959 663 B
Bauteil: J532_DCDCStab H05 0006
Seriennummer: 11038000624011200410
Adresse 42: T¸relektr. Fahrer (J386) Labeldatei:. 8K0-959-793.clb
Teilenummer SW: 8K0 959 793 N HW: 8K0 959 793 N
Bauteil: TSG FA H12 0357
Revision: Seriennummer: 0000112652569
Codierung: 011002204000410001
VCID: 4B92F40AEAA09F1E2F-801E
Adresse 46: Komfortsystem (J393) Labeldatei:. DRV\8K0-907-064-46.clb
Teilenummer SW: 8K0 907 064 CP HW: 8K0 907 064 CP
Bauteil: BCM2 2.0 H05 0435
Revision: 00002001 Seriennummer: 0143555993
Codierung: 0100062020B904408120023680000000
Adresse 52: T¸relektr. Beifahr. (J387) Labeldatei:. 8K0-959-792.clb
Teilenummer SW: 8K0 959 792 N HW: 8K0 959 792 N
Bauteil: TSG BF H12 0357
Revision: Seriennummer: 0000112726585
VCID: 4A9CF10EE5DA861614-801E
Adresse 53: Feststellbremse (J540) Labeldatei: DRV\8K0-907-801-V1.clb
Teilenummer SW: 8K0 907 801 H HW: 8K0 907 801 H
Bauteil: EPB Audi B8 H09 0100
Revision: 00000003 Seriennummer: 00000000855847
VCID: 34608FF6975EE0E65E-8060
Adresse 55: Leuchtweitenreg. Labeldatei: DRV\8K0-907-357.clb
Teilenummer: 8K5 907 357 B
Bauteil: Dynamische LWR H02 0010
Revision: 00000001 Seriennummer:
Codierung: 0000004
VCID: 397EBEC2703C1D8E8D-806C
Adresse 56: Radio (J503) Labeldatei:. 8Tx-035-1xx-56.clb
Teilenummer SW: 8T1 035 186 P HW: 8T1 035 186 P
Bauteil: Concert3 H07 0350
Revision: 00000011 Seriennummer: AUZ5Z6K1537374
Codierung: 0500048204028100015B070000
VCID: 4480DF36C7FE5066EE-8010
Subsystem 1 - Teilenummer SW: 8T0 919 603 F HW: 8T0 919 603 F
Bauteil: Display
Adresse 62: T¸relektr. hi. li. (J388) Labeldatei:. 8K0-959-795.clb
Teilenummer SW: 8K0 959 795 F HW: 8K0 959 795 F
Bauteil: TSG HL H11 0357
Revision: Seriennummer: 0000113048695
Codierung: 010002204000210001
VCID: 4586C232CCC4696EF9-8010
Adresse 69: Anh‰nger (J345) Labeldatei:. DRV\8K0-907-383.clb
Teilenummer SW: 8K0 907 383 E HW: 8K0 907 383 E
Bauteil: Anhaenger H09 0100
Revision: 1A001001 Seriennummer: 00000146620353
Codierung: 0100000000000000
VCID: 3664B5FE8122F2F660-8062
Adresse 72: T¸relektr. hi. re. (J389) Labeldatei:. 8K0-959-795.clb
Bauteil: TSG HR H11 0357
Revision: Seriennummer: 0000113048722
Adresse 77: Telefon Labeldatei: DRV\8P0-862-335.lbl
Teilenummer SW: 8T0 862 335 E HW: 8T0 862 335 E
Bauteil: FSE_256x BT H42 0650
Revision: 00000000 Seriennummer: 00000005264407
Codierung: 0010310
VCID: 3C70A7D67F0E28A696-8068
Ende----------------------------(Dauer: 02:53)-----------------------------
Translated on 29-10-2026, 11:01.
a4b82.0tdi
Post24-10-2017, 20:59    Subject: Quote
I accidentally selected the gasoline engine instead of the diesel engine, but I didn't actually make any changes. I just wanted to demonstrate that he doesn't modify channels 53 and 55, whether it's a diesel or a gasoline/petrol engine.
Translated on 31-10-2026, 9:55.
Post25-10-2017, 8:17    Subject: Quote
kapiere nicht was Du mit Benzinmotor/Dieselmotor jetzt genau meinst mit "erwischt", die Servicerückstellung muss, falls unterschiedliche Einträge im Servicerückstellungs-Dropdown da sind, natürlich für den richtigen Motortyp gemacht werden.
Warum wurde
49 Zeit (Minimum) bis Service Tag(e) 730 365
geändert?
a4b82.0tdi
Post27-10-2017, 19:36    Subject: Quote
werde die nächsten Tage antworten und inzwischen weiter nach Informationen zu meinen Fehlern bzw. Fehlercodes bei 01: Motorelektronik: 4695 4698 4699 und bei 08: Klima-/Heizungsel. 01271 suchen.
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG Longlife Oil Standards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reset Service Light (Cars '98+) On-Board Diagnostics (OBD)
No new posts Service zurücksetzen Audi A3 8p On-Board Diagnostics (OBD)
No new posts Skoda Octavia 1Z: Reset Service Light On-Board Diagnostics (OBD)
No new posts Long Life Service: Your Car's Extended Warranty On-Board Diagnostics (OBD)
