Engine Misfire? Next Drive is Fine
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
DieselcoupeTDI
Post24-10-2017, 16:03    Subject: Engine Misfire? Next Drive is Fine Quote
'For the past few days, I've been experiencing engine misfires. Then it starts emitting blue smoke and the car smells terrible.'
Data: Passat 3C, BMP (automatic transmission), 120,000 km mileage, new dual-mass flywheel, new tandem pump, new EGR valve, VVP (valve body) replaced one year ago, new exhaust system from catalytic converter.
'The data is all fine (as long as the engine is running smoothly). Every time I read the data with VCDS, the car was working perfectly.'
Does anyone have any ideas?
My suspicion is that a nozzle has an electrical problem - which isn't visible when measuring.
Thank you, and if anyone has had a similar request before, please provide a link to it.
Translated on 22-08-2026, 13:47.
Post24-10-2017, 16:36    Subject: Engine Misfire? Next Drive is Fine Translating...
[Translating...]
Autoscan?
DieselcoupeTDI
Post31-10-2017, 22:10    Subject: Engine Misfire? Next Drive is Fine Quote
The scan is coming. I'm currently on vacation.
Now, even the indicator light was blinking, and the emergency program has been activated.
I think the particulate filter is clogged. It has 320,000 km on it!
When I'm back home on Sunday, I will read aloud.
Translated on 22-08-2026, 13:49.
Post31-10-2017, 22:27    Subject: Engine Misfire? Next Drive is Fine Quote
Perhaps the flux capacitor has a loose connection...?
"First, get the data organized and run the auto-scan, then we can proceed. It seems like you're on vacation far away if you're racking up 200,000 km so quickly. If that was the easy part, there will definitely be a few more tasks for VCDS on the way back, and you can easily run the auto-scan in the meantime."
Translated on 22-08-2026, 13:50.
DieselcoupeTDI
Post07-11-2017, 15:45    Subject: Engine Misfire? Next Drive is Fine Quote
Okay, the part about San will come later. (It's for Windows XP and requires a USB stick.)
Here are some photos.
I think my ash value is full, right?
Oh yeah, my new PC isn't recognizing the dongle - picture.
 File size:  1.51 MB
 Viewed:  302 times
 File size:  2.04 MB
 Viewed:  284 times
 File size:  1.65 MB
 Viewed:  633 times
Translated on 22-08-2026, 13:51.
Post07-11-2017, 16:07    Subject: Engine Misfire? Next Drive is Fine Quote
"I'm sorry, but you are not a customer, so please contact the seller of your device. icon_idea.gif They made money from you and are therefore responsible for providing support."
Furthermore, your images are from two different systems, and neither of them is ours. icon_rolleyes.gif
Translated on 22-08-2026, 13:52.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor Performance Loss and Stalling Diesel Engine Technology
No new posts Engine stall problem On-Board Diagnostics (OBD)
No new posts Is the DPF okay? On-Board Diagnostics (OBD)
No new posts Engine Mounts: Are They Still Good? Diesel Engine Technology
