Neukauf Audi 80 1Z 1.9 TDI rußt stark und ruckelt | Posts 32+
Go to page: Previous  1, 2, 3
phanlezz likes this.
Post18-10-2017, 11:40    Subject: Quote
The search function is your friend.
I'm sorry, but I cannot access external websites or specific files online, including the URL you provided. Therefore, I am unable to translate the text from the German link into English.
Black smoke certainly won't disappear with a simple adjustment, as the adjustment range is too small before the engine control unit detects that something is wrong. However, if the jerking is caused by the same issue, it might be resolved. You still need VCDS for proper adjustments.
Translated on 04-07-2026, 19:56.
phanlezz
Post11-11-2017, 14:11    Subject: Quote
Hello everyone,
Unfortunately, I'm currently unable to proceed without the appropriate software and the right tools for working on it.
Currently, it only starts for a short time, but then usually turns off again almost immediately.
I replaced the seals on the dosing system because the pump was leaking, but now the already poor calibration is probably even more off.
Unfortunately, given the current temperatures and my level of expertise, it no longer makes sense to continue working on the car. A new pump would be an economic disaster (the car has over 500,000 km on it).
If I can't find a knowledgeable hobby mechanic nearby, then it will end up at the scrapyard or be exported.
Just wanted to keep you updated.
Greetings.
Translated on 04-07-2026, 19:57.
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 5zylinder(VAG) v70 tdi motor rußt stark... Diesel Engine Technology
No new posts VW Bora ARL - Runs and jerks severely under load Diesel Engine Technology
No new posts AAT rußt ruckelt und zieht manchmal nichts vom Teller Diesel Engine Technology
No new posts AUDI 80 ABK - Severe shaking/vibration at low RPM in all ... Gasoline Engine Technology
