Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
12-11-2017, 18:58 Subject: Audi A3 8P: Rear View Camera Issues |
Quote: | Sunday, November 12, 2017, 13:47:01:26778
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 8.1 x64.
VCDS Version: RKS 17.8.0.1 HEX-V2 CB: 0.4408.4
Data as of: 20171026 DS276.6
Vehicle Identification Number: WAUZZZ8P8AB022687. License plate: [Missing information]
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Address 62: Door electric strike, left/right.
Label file: DRV\8P4-959-801.lbl
Control unit part number: 8P4 959 801 F. Hardware: 8P4 959 801 F.
Component and/or version: Door module SG, H04 0050.
Encoding: 0131216
Operating number: WSC 00046 412 1012544
VCID: 42DE4065888958B70DE-8016
"One error found:"
01554 - Motors for rear central locking doors; LOCK.
012 - Electrical fault in the circuit.
Address 72: Door electric strike, high, right.
Label file: DRV\8P4-959-802.lbl
Control unit part number: 8P4 959 802 F. Hardware: 8P4 959 802 F.
Encoding: 0131216
VCID: 43D04561979351BF068-8016
2 error codes found:
00931 - Rear right central locking latching unit (F223)
008 - implausible signal.
What do you think? Should I check the wiring harness to the door, or should I just remove the door panel?
Translated on 17-09-2026, 2:00.
Profile PM WWW Garage |
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
dieselschrauber likes this. |
12-11-2017, 20:42 Subject: Audi A3 8P: Rear View Camera Issues |
Hello.
Have you ever looked at the material weight breakdown (MWB) for doors?
It might be possible to determine if the microswitches are still working or if the signals change when you open and close the door, or when it is closed/open.
Regards, Mpire. fehlen Dir die Worte, entscheiden die Taten!
Translated on 17-09-2026, 2:04.
Profile PM Garage |
12-11-2017, 21:08 Subject: Audi A3 8P: Rear View Camera Issues |
Good idea!
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2405 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
13-11-2017, 9:00 Subject: Audi A3 8P: Rear View Camera Issues |
Hi Rainer,
Have you checked the SLP to see if the rear doors share a common "lock" connection?
If that were the case, I would suspect a fault on the right rear side, which would be correctly detected on both the right and left sides.
Greetings.
Guste.
Translated on 17-09-2026, 2:05.
Profile PM Garage |
