mickdoohan Guest
21-10-2003, 9:19 Subject: Crankshaft Bolt for TDI 90 PS (ALH) |
'Hi, does anyone know the torque specification for the central bolt of the crankshaft (the one that secures the toothed wheel for the timing belt), and the size of the socket needed for the bolt? The bolt has a 12-point spline head. Is this also possibly a stretch bolt, and does it need to be replaced? Car: Audi A3 TDI 90 hp (ALH), year 2001. Thanks.'
Translated on 27-10-2026, 11:34.
golf3schrauber Blaumann
Joined: 10/15/2003 Posts: 140 Karma: +1 / -0 Location: Erkelenz
21-10-2003, 16:07 Subject: Crankshaft Bolt for TDI 90 PS (ALH) |
Okay, so for the 1Z, AHU, AEY, AFN, AVG, and ALE engines.
90 Nm + tighten a quarter turn (90°).
The screw must always be replaced. The threads and contact surfaces should be free of grease.
A 19mm Torx socket fits onto the screw head. Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
21-10-2003, 16:51 Subject: Crankshaft Bolt for TDI 90 PS (ALH) |
For ALH engines, the torque specification is 120 Nm, plus an additional 90 degrees of tightening.
Always replace screws. Tschüss
Michael II
Translated on 27-10-2026, 11:35.
