AIFO Iveco 8061 Engine Stalling / Rough Running
chris3333
Post14-12-2017, 13:11    Subject: AIFO Iveco 8061 Engine Stalling / Rough Running Quote
Hello everyone,
I could really use your help.
I'm having a problem with a diesel engine. So far, I've checked the injectors, and they are okay. The compression is between 18 and 22 bar on all cylinders, which is within the tolerance range. The next step would be to take the fuel injection pump to Bosch Service for inspection. Here are two videos showing the problem. Video 2 shows the faulty engine, and video 1 is for comparison with a working one.
Engine manufacturer: AIFO Iveco.
Model: 8061 SM Turbo.
Power output: 165 hp.
2-stroke or 4-stroke diesel engine, manufactured before 1980.
Number of cylinders: 6.
Engine serial number: 768701.
What are your thoughts on this?
Sure, here's the translation:
"Thank you in advance."
Christian.
AIFO Iveco 8061 Engine Stalling / Rough Running - Aifo8061-funktioniert.mp4
 File size:  2.39 MB
 Viewed:  2350 times
AIFO Iveco 8061 Engine Stalling / Rough Running - Aifo8061-defekt.mp4
 File size:  2.44 MB
 Viewed:  884 times
Translated on 12-07-2026, 2:10.
jarobaldu
Karma: +40 / -0   Thank you, like it!
Post14-12-2017, 14:08    Subject: AIFO Iveco 8061 Engine Stalling / Rough Running Quote
Hi there,
What is the injection timing?
Do the exhaust fumes smell like unburned diesel?
Adrian.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 12-07-2026, 2:12.
chris3333
Post14-12-2017, 14:16    Subject: AIFO Iveco 8061 Engine Stalling / Rough Running Quote
Apparently, only one cylinder is malfunctioning. Therefore, it can't be an issue with the injection timing.
Translated on 12-07-2026, 2:13.
Goggomobil
2008 Volkswagen Touareg
Post14-12-2017, 14:46    Subject: AIFO Iveco 8061 Engine Stalling / Rough Running Quote
What is the valve actuation mechanism like?
Camshaft worn out, rocker arm bent, adjustment screw came loose, pushrod bent?
And yes, even if something is missing on the output side, it still has excellent compression.
I once had an engine where the exhaust camshaft was almost completely worn out, and it sounded exactly like that.
Best regards, Christian.
VW Touareg, Bj 2008, CASA
Renault Kangoo, Bj 2001, K4M752
Coronet 21DC, Bj 1967, 2xRenault J8S240
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber likes this.
Post14-12-2017, 15:02    Subject: AIFO Iveco 8061 Engine Stalling / Rough Running Quote
Hello.
Keep the engine running and then, one by one, loosen the union nut of the fuel injector line for each cylinder.
In the affected cylinder, no difference should be noticeable, while the performance of the other cylinders will continue to deteriorate. This way, you can identify the problematic cylinder.
Now you can try swapping the nozzles to see if the problem moves along with them.
What type of fuel injection pump does this engine have?
It is apparently available with both a series pump and a distribution pump.
There's another way to check the check valves of the common rail system; sometimes the springs break. These valves are found in both types of pump designs and are located in the connector where the injection line is attached to the pump.
You can do that yourself; you don't need a Bosch service for it.
Mpire
Translated on 12-07-2026, 2:15.
chris3333
Post14-12-2017, 15:38    Subject: AIFO Iveco 8061 Engine Stalling / Rough Running Quote
"Good idea, it's a Bosch PES 6A inline fuel pump. If a spring were broken, would I get too much or too little diesel to the corresponding cylinder? I tried to open the lines, but the result isn't clear to me. Cylinders 1-5 run slightly worse, and cylinder 6 is running very unevenly. I can't make sense of that..."
Translated on 12-07-2026, 2:17.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post14-12-2017, 15:42    Subject: AIFO Iveco 8061 Engine Stalling / Rough Running Quote
chris3333 wrote:
Good idea, it's a Bosch PES 6A inline fuel injection pump. If a spring were broken, would I get too much or too little diesel for the corresponding cylinder?
You're getting something less than what you should, and it's arriving much too late, which could explain the blue smoke.
Mpire.
chris3333
Post14-12-2017, 15:53    Subject: AIFO Iveco 8061 Engine Stalling / Rough Running Quote
Mpire
Could this also lead to the type of misfires that can be heard in the video? In my opinion, the blue smoke is normal in these generations of engines as long as they are cold. Then, some engine oil is burned until the pistons reach their correct size due to warming up. This is also the case with DAF engines from the 1970s.
Translated on 12-07-2026, 2:18.
chris3333
Post15-12-2017, 17:04    Subject: Problem solved. Quote
Thank you for your information. A pre-chamber has burned out.
Best regards to everyone!
Christian.
Translated on 12-07-2026, 2:19.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post15-12-2017, 18:23    Subject: AIFO Iveco 8061 Engine Stalling / Rough Running Quote
Thank you for the feedback icon_smile_thumb_up.gif.
Good luck with the repair.
Mpire
Translated on 12-07-2026, 2:20.
No new posts Misfires on 2.0 TDI engine, rough running Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Misfire: 2.4L & 2.8L Motors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Uneven idle speed on the AXR engine Diesel Engine Technology
No new posts Peugeot Boxer: Rough Running - Diagnosis & Repair Diesel Engine Technology
This topic is locked, you cannot edit or reply. 2.0 TDI - Germany - Engine misfiring, white smoke Diesel Engine Technology
No new posts Rough running 1.6 TDI Cayenne, constant injector failure Diesel Engine Technology
