P0148 - Fuel Supply Malfunction (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Post16-12-2017, 0:00    Subject: P0148 - Fuel Supply Malfunction Quote
Error code P0148 - A fuel supply error typically occurs when the engine is not receiving enough fuel under heavy load.
Possible symptoms:
- MIL (Malfunction Indicator Lamp) light is illuminated on the instrument cluster.
- Loss of power and stuttering at higher RPMs and under heavy load.
- Jerky movement, starting problems.
Possible causes:
- The fuel system has a leak.
- Fuel filter clogged.
- Fuel pump (pre-pump) and/or high-pressure pump is defective or delivering insufficient pressure.
- Malfunction in fuel pressure regulation (check pressure sensor and pressure control valve).
Ratings - P0148 - Fuel Supply Malfunction
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G28 Error: Find the Mistake! Diesel Engine Technology
No new posts ABS error On-Board Diagnostics (OBD)
No new posts AGR errors On-Board Diagnostics (OBD)
No new posts WFS Errors: Troubleshooting and Solutions Diesel Engine Technology
