VCDS MicroCan: Can't Edit Adaptation Channel
casiosv
2006 Volkswagen Passat
Post30-01-2018, 18:26    Subject: VCDS MicroCan: Can't Edit Adaptation Channel Quote
I wanted to modify an adaptation channel in the central electronics control unit (part number 5Q0 937 086 BM) of my Passat B8, manufactured in 2018.
It is about the following channel:
IDE11477-ENG128480- Interior lighting parameter - p_t_delay_entry_footwell.
Unfortunately, my VCDS MicroCan device is giving me an error message stating that the interface cannot send telegrams larger than 256 bytes. But isn't the channel exactly 256 bytes in size?
Unfortunately, I don't have an automatic scan available right now. I can run one if you'd like.
 File size:  235.14 KB
 Viewed:  1890 times
Passat B8 Variant
Translated on 25-10-2026, 13:02.
Post30-01-2018, 18:43    Subject: VCDS MicroCan: Can't Edit Adaptation Channel Quote
das Problem ist die Firmware im MicroCAN, das zu sendende Telegramm ist schlicht zu lang. Dein MicroCAN ist von 2012, es wird seit geraumer Zeit nicht mehr produziert. Why?
In vehicle models from the 2018 model year onwards, depending on the model and equipment, control units are installed that require such long telegrams for these types of operations.
-> Current diagnostic hardware is required, such as HEX-V2 or HEX-NET.
https://shop.dieselschrauber.org/en/vcds-kfz-diagnose-c-23.php
Translated on 25-10-2026, 13:03.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM baud rate cannot be synchronized On-Board Diagnostics (OBD)
No new posts VAG COM: Baud rate synchronization failed... On-Board Diagnostics (OBD)
No new posts Replacement key cannot be adjusted? On-Board Diagnostics (OBD)
No new posts TDI ALH: Can't Adjust Injection Timing with VCDS? Diesel Engine Technology
