3.0 BiTDI Injector Values: Tuning & Optimization
Krennzen
Post10-02-2018, 1:56    Subject: 3.0 BiTDI Injector Values: Tuning & Optimization Quote
Hello!
I could use your help. My name is Chris, I'm 26 years old, and I come from Lower Austria.
I drive an Audi A6 4G sedan with a 3.0 biTDI engine (313 hp / CGQB).
Currently, I feel like my car is running a bit rough at idle because it's vibrating more than it was a few months ago.
I'm guessing it's the injectors, as I've had a faulty injector before (cylinder 5 was replaced about 5,000 km ago).
Attached are the VCDS diagnostic data for all 6 cylinders (rail pressure calibration points 1, 2, and 3).
However, I can't make sense of the values...
I still have a new injector available, and if there are any other worn-out parts, I will replace those as well. However, I am looking for someone who can analyze the values/readings.
Thank you very much and best regards.
Chris.
 VCDS Kalibrierpunkt 3
 File size:  3.76 MB
 Viewed:  2349 times
 VCDS Kalibrierpunkt 2
 File size:  3.49 MB
 Viewed:  2105 times
 VCDS Kalibrierpunkt 1
 File size:  3.57 MB
 Viewed:  1675 times
Translated on 26-07-2026, 13:34.
Post10-02-2018, 11:26    Subject: 3.0 BiTDI Injector Values: Tuning & Optimization Quote
This topic is clearly relevant for diagnosis, and you acquired the VCDS where no support is included. However, this support can be purchased:
We cordially invite you to participate. The requirement for posting in topics related to diagnostics (anything that requires a vehicle diagnostic system) is...
a diagnostic tool from the diesel mechanic shop or
our software, including KDataScope and KPower, or the Diesel Mechanic license.
a vehicle diagnostic support key.
Diesel mechanic customers receive enhanced support (expert assistance) and full access.
Translated on 26-07-2026, 13:36.
No new posts VW T5, 2.0 BiTDI, excessive oil consumption Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 BiTDI Engine Problems & Repairs Diesel Engine Technology
