Mercedes G290TD Diagnosis: OM602.983 (W461)
Mark1234
2000 Mercedes-Benz G Class
Post02-04-2018, 17:59    Subject: Mercedes G290TD Diagnosis: OM602.983 (W461) Quote
I am a customer who uses VCDS and GS911 diagnostic tools, and I now own a Mercedes (see above). The vehicle has a 38-pin connector installed.
Is it possible to read the engine control unit (ECU) data using VCDS? Which adapters are necessary?
Mercedes EVE Bosch distributor injection pump N3/8.
MB No.: 026 545 15 32
Bosch Part No. 0281001953 BOSCH EDC 1.4 (MSA 15.2-3.23)
Hardware Version 45/95
Software Version 21/98
I also have a Carsoft 7.4 multiplexer.
Thanks & Regards,
Mark.
Touareg V10 TDI, BMW 1200 GS ADV
Translated on 18-09-2026, 16:42.
Post03-04-2018, 17:31    Subject: Mercedes G290TD Diagnosis: OM602.983 (W461) Quote
Is it possible to read the engine control unit with VCDS
No, if that were possible, then OBD2 would be an option, but if your Benz had it, it would also have the OBD2 port in the car.
Translated on 18-09-2026, 16:44.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW & Mercedes Diagnostic Kit: Which One to Buy? On-Board Diagnostics (OBD)
No new posts Ford Focus TDI Diagnostic Tool (2000) On-Board Diagnostics (OBD)
No new posts Can I install a motor control unit from a W210 E290 TD in... On-Board Diagnostics (OBD)
No new posts Mercedes LMM to VW: Conversion Guide Diesel Engine Technology
