Polo 6N Hydraulic Pump
vag-driver
Post19-03-2018, 8:21    Subject: Polo 6N Hydraulic Pump Quote
"Recently, I've been encountering this error message:"
Address 03: Brake Electronics Label file: DRV\1J0-907-37x-ABS.lbl
Part number: 1J0 907 379.
Component: ABS ITTAE 20 GI V00
Encoding: 01901
Operating number: WSC 01901
VCID: 6ED5F8BD2ADCBC310B-4AB4
"One error found:"
01276 - ABS hydraulic pump (V64)
16-00 - Signal out of tolerance.
So far, I have checked the connector to the SG for corrosion, but I didn't find anything. Is the pump actually defective, or is there another possible cause?
Andreas
Translated on 08-10-2026, 8:41.
Post19-03-2018, 14:02    Subject: Polo 6N Hydraulic Pump Quote
The relays inside the ABS module are also prone to corrosion.
Translated on 08-10-2026, 8:42.
chli1976
Post19-03-2018, 16:56    Subject: Polo 6N Hydraulic Pump Quote
Have you checked the blade fuses on the battery?
VCDS
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post19-03-2018, 19:59    Subject: Polo 6N Hydraulic Pump Quote
Hello.
Is that the same Polo as last time?
Have you compared the speed signals from the sensor rings yet?
Are they stable in terms of their values, or do they fluctuate?
I think the segment rings are dirty/rusty.
Most likely, the rear components are the same for the 6N Polo as they are for the Lupo.
Back then, I wrote:
Hello.
04/25/2017
Forget the pump; the error indicates a faulty sensor ring on the rear axle. It's not the sensor itself, but the ring (part number 191614149) on the hub that rotates.
Why I say that.
Because our Lupo TDI had exactly this problem for a long time (about a year).
After restarting, the error disappeared, but it reappeared at a speed of slightly over 20 km/h, just like it did for you.
I tried replacing all sorts of things without success, but it wasn't until I replaced the rear right wheel bearing that I noticed the damage to the ring. After replacing the entire hub, including the ring, the problem disappeared and never came back.
"Our Lupo has drum brakes on the rear. The adjuster wedge had become stuck and seized up... Now, when the handbrake is engaged, the lever where the cable is attached moves too much and rubs against the sensor ring."
Consequently, the small gaps in the ring are compressed, and the wheel speed signal is no longer accurate.
This can also happen due to the accumulation of metallic debris, or due to corrosion of the ring caused by age.
It could also be on the front, as the ring is also made of thin sheet metal, which is prone to rusting away.
To make your search easier, use VCDS. First, go to the ABS control unit and find the measuring block (MB) where you can see the four fields representing all four speeds. Start the engine, start driving, and begin at a slow speed, gradually increasing the speed.
The good signals are consistently uniform and rise synchronously, while the value of the faulty ring fluctuates sporadically and usually lags behind.
The ring is available individually under the part number listed above for 8-10€, but I would always recommend replacing both at the same time.
Greetings Mpire
Regards, Mpire.
Translated on 08-10-2026, 8:45.
vag-driver
Post20-03-2018, 10:17    Subject: Polo 6N Hydraulic Pump Quote
To do that, the SG (presumably a component) needs to be removed and opened. I haven't done that yet.
chli1976 wrote:
Have you checked the fuse covers on the battery?
Both the fuse protecting the wiring harness and the 20A fuse in the fuse holder, which is located in front of and not on top of the battery in this model, are okay.
Mpire wrote:
Hello.
Back then, I wrote:
Hello.
04/25/2017
Why I say that.
"Our Lupo has drum brakes on the rear. The adjuster wedge had become stuck, seized up, or something like that. Now, when you pull the handbrake, the lever where the cable is attached moves too much and rubs against the sensor ring."
It's also possible that the problem is located at the front, as the ring is also made of thin sheet metal, which is prone to rusting.
Greetings Mpire
Greetings Mpire
Yes, I had completely forgotten that I posted that back then icon_rolleyes.gif.
I will perform the measurements using VCDS at the appropriate time. I'm surprised that, even after almost a year, the ABS hasn't reported any errors. The car is driven daily.
Andreas
Translated on 08-10-2026, 8:51.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post20-03-2018, 17:39    Subject: Polo 6N Hydraulic Pump Quote
Hello.
The drum brakes, in particular, can deposit a significant amount of dirt into the gaps of the sensor ring. If enough large, ferromagnetic particles (rust, wear debris, etc.) distort the signal and are then flung out, this can create an error pattern, or the error may disappear again.
Why don't you remove the two drums and take a look? It should only take a maximum of 5 minutes per side icon_wink.gif.
Regards, Mpire.
Translated on 08-10-2026, 8:56.
vag-driver
Post20-03-2018, 18:11    Subject: Polo 6N Hydraulic Pump Quote
I suppose I'll have to. I don't understand why the error can't be cleared then. In the case you described, I would expect the error to be clearable and reappear on the next trip. However, that's not what's happening here. The error is constantly active and cannot be cleared.
Andreas
vag-driver
Post27-03-2018, 19:04    Subject: Polo 6N Hydraulic Pump Quote
As recommended, I checked measurement block 1. All speed sensors are responding without delays and consistently. In this case, that is definitely not the problem.
Andreas
Translated on 08-10-2026, 8:57.
Post27-03-2018, 19:39    Subject: Polo 6N Hydraulic Pump Quote
I suspect the error message refers to the pump located within the hydraulic block, which houses the pump valves.
vag-driver
Post06-04-2018, 7:44    Subject: Polo 6N Hydraulic Pump Quote
Every year, again...
Apparently, this error occurs almost every year around the same time and then disappears on its own.
Yesterday, the ABS warning light went off after starting the car, as it should. Let's see how long it stays off.
Due to a lack of time, I haven't been able to replace the hydraulic block yet.
Andreas
Translated on 08-10-2026, 8:58.
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Noises & Sounds - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 01276 - ABS Hydraulic Pump V64 On-Board Diagnostics (OBD)
No new posts Audi A3 Hydraulic Pump Problem - 1996 Diesel Engine Technology
No new posts Polo 86c, year of manufacture 1992 Gasoline Engine Technology
No new posts Polo 6R On-Board Diagnostics (OBD)
