Engine Control Unit (ECU) software version and chip tuning check
Motosteuergerät Softwareversions- und Modifikationscheck
Sinnvoll brauche ich
95%
 95%  [ 19 ]
Braucht kein Mensch
5%
 5%  [ 1 ]
Total votes : 20
Post07-01-2018, 14:15    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
Would it be helpful to include a note in the diagnosis indicating that a newer software version exists for the engine control unit, and if so, which one?
At the same time, for vehicles meeting EU5 standards or higher, an integrity check of the engine control unit (ECU) software could be performed to determine whether it is original or has been modified.
How useful do you find this feature?
Translated on 18-07-2026, 4:19.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post07-01-2018, 17:10    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
Hello.
I would find that very useful.
- I usually have VCDS with me when buying a car or during a test drive.
With this function, one could already infer certain "things" and potentially make a better purchasing decision icon_wink.gif.
- When troubleshooting issues on customer vehicles, knowing about undocumented or unauthorized modifications could make it easier to pinpoint the source of certain problems.
- or alternatively, you can inform the customer that a newer software version is available, which the original equipment manufacturer (OEM) intends as a solution to the problem.
Mpire
Translated on 18-07-2026, 4:20.
Post07-01-2018, 20:41    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
I would also find a reference to a more recent version helpful. You don't necessarily have to rely on the workshop for that information.
Translated on 18-07-2026, 4:21.
Karma: +585 / -0   Thank you, like it!
Post07-01-2018, 23:15    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
Hi!
If it's possible, it would be a very worthwhile endeavor.
brezelmann01
Post07-01-2018, 23:17    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
I would also think that's great, but on what data basis could it be reliably evaluated?
Pretzelman.
Translated on 18-07-2026, 4:22.
Post08-01-2018, 10:14    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
Brezelmann
It's highly likely that the corresponding tool will read the data through diagnostics, making user manipulation a rather unlikely scenario – almost like finding a "pink elephant." While it might be technically possible, who would do it and why would they bother? It's absolutely manageable.
And a data or software version that doesn't appear anywhere else would be even more suspicious.
Translated on 18-07-2026, 4:23.
Post18-01-2018, 16:50    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
A test version of KOBD2CHECK, which provides information about newer software versions and indicates whether an existing CVN is genuine (i.e., the engine control unit software is original), is complete. icon_razz.gif
Download: see attached .rar archive. Please note that the trial version only works with the Diesel Mechanic RKS+CAN interface. This is included with the "OBD2 Diagnostic Kit" and the "CAN-USB Interface Kit". icon_idea.gif
In order to display the information, KOBD2CHECK needs internet access. To start the scan, click the [Scan] button in KOBD2CHECK.
Translated on 18-07-2026, 4:25.
chli1976
Karma: +185 / -0   Thank you, like it!
Post18-01-2018, 17:55    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
Is that just an example in the Screenshot?
For this part number, the software version is 4150.
VCDS
Translated on 18-07-2026, 4:26.
chli1976 likes this.
Post18-01-2018, 18:44    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
The following software versions are available for product 03G906016ME: 0945, 1141, and 4150.
Translated on 18-07-2026, 4:27.
Post20-01-2018, 14:16    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
KOBD2Check has been further refined and is now ready for production use. icon_smile_thumb_up.gif
Product in the shop: https://shop.dieselschrauber.org/en/obd2-diagnose-kit-p-321.php
The software package for testing the RKS+CAN CAN bus interface is attached.
 Prüfung auf neueren Softwarestand des Motorsteuergeräts.
Sofern vom Motorsteuergerät unterstützt, Prüfung der Steuergerätesoftware auf Modifikation.
 File size:  94.18 KB
 Viewed:  1311983 times
RKS+CAN_GER_370-Installer.rar
 Installationspaket für RKS+CAN (Dieselschrauber/CANHack) CAN-Bus Interface.
 File name:  RKS+CAN_GER_370-Installer.rar
 File size:  7.53 MB
 Downloaded:  417 times
Translated on 18-07-2026, 4:28.
Post02-02-2018, 19:48    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
The calibration ID seems to be outputted in different formats...
I would be grateful if you could provide me with the results of a KOBD2Check scan (see the image "ECU-software-check-KOBD2Check.jpg" above).
User_5841264171
Post11-04-2018, 23:11    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
I'm using Kobd2check v1.70 - SCAN and I want to check if there's a newer software version available for my engine control unit, or whether the current CVN is the original one. However, it always only displays the existing software version and CVN, regardless of which vehicle I scan? And this is happening even though I have an internet connection.
Calibration ID: 03L906018PT 9980
CVN: 3F0B6B78
Greetings.
Translated on 18-07-2026, 4:29.
Post12-04-2018, 9:44    Subject: Engine Control Unit (ECU) software version and chip tuning check Quote
Hi.
However, it always only displays the existing software version and CVN, regardless of which vehicle I am examining.
No, as I interpret the database, the vehicle you mentioned is the only one that you checked.
The database grows as it is used more. However, for your VAG part number of the engine control unit, there was no entry yet for this software version; it will be automatically added when the data is read. The more people scan their cars, the faster the database grows.
9980 should currently be the latest software version for your engine control unit.
If a newer software version or the same version with a different CVN exists in the database, KOBD2Check will display corresponding information to you (an active online connection is required).
Translated on 18-07-2026, 4:31.
No new posts Batterie (Akkumulator): Tipps zu Check und Wartung Technical Articles
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Doku, n.löschb. Fehler im Motorsteuergerät 2.5l V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is chip tuning detectable via OBD check? Diesel Engine Technology
No new posts Motorsteuergerät / Softwarestand auslesen On-Board Diagnostics (OBD)
No new posts Softwarestand am 038 906 012 AT aendern Diesel Engine Technology
No new posts Software Version: MSG Part Number Lookup On-Board Diagnostics (OBD)
