Headlight Washers Not Working? Fix It Now!
Bertl100
Karma: +1 / -1   Thank you, like it!
Post12-04-2018, 16:59    Subject: Headlight Washers Not Working? Fix It Now! Quote
Hello forum,
Here's a brief overview of my vehicle details:
Audi A6 Avant 3.0 TDI (year 2006) S-Line.
I need to get the headlight washer system repaired for my vehicle inspection because it's not working. I wasn't even aware that I had such a system.
Since I don't want to just tear everything apart like a gorilla, it would be great if someone with experience could help me.
The following symptoms have occurred:
* Refilling the washing water --> OK.
* First time spraying --> The window is being sprayed.
* Afterwards, the windshield washer fluid leaks out almost completely from behind the left bumper.
Can anyone offer any advice on where to look or what steps to take?
Best regards.
Robert.
Translated on 21-09-2026, 0:53.
Back to top Profile PM Email
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber likes this.
Post12-04-2018, 17:53    Subject: Headlight Washers Not Working: Troubleshooting Quote
Bertl100 wrote:
* After that, the windshield washer fluid leaks out almost completely from behind the left bumper.
I would like to remove the bumper and try to locate the source of the leak.
Pressure must be able to build up in the system, otherwise the two cylinders/nozzles will not open.
It's possible that there wasn't enough antifreeze in the system at some point, and a freeze caused a crack in the system.
Regards, Mpire.
Translated on 21-09-2026, 0:55.
Karma: +645 / -0   Thank you, like it!
Post13-04-2018, 10:55    Subject: Headlight Washers Not Working? Fix It Now! Quote
Open the hood, have an assistant operate the SRA (presumably a diagnostic tool), and check where the water is coming from. You can't see anything from underneath, and you still can't see anything. Lower the bumper.
Translated on 21-09-2026, 0:56.
Bertl100
Post13-04-2018, 12:50    Subject: Headlight Washers Not Working? Fix It Now! Quote
I will do that, thank you!!
No new posts Golf 1J Headlight Washer Pump Leak - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Failure: Troubleshooting & Repair Guide On-Board Diagnostics (OBD)
No new posts MKB: ARL PDE failure? Upload
No new posts LMM failure? On-Board Diagnostics (OBD)
No new posts AVF: What's wrong with it? Upload
