Reverse Light BMW E91 320d 2005
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
chli1976
Post17-04-2018, 19:56    Subject: Reverse Light BMW E91 320d 2005 Quote
I have a BMW E90 where the reverse lights and the fog light on both sides are not working.
According to the original tester, there's a short circuit on the right side. I checked the cables from the lamps to the footwell module and they all have continuity. I also tested for shorts to both positive and ground, but couldn't find anything. Finally, I applied voltage to the corresponding cables at the connectors of the footwell module, and the lights came on.
While reading the original test report, it stated that if the footwell module detects a short circuit and the short circuit is still detected after 50 ignition cycles (on/off), the corresponding output will be permanently disabled, and a new footwell module is required.
Perhaps there's a BMW specialist here who can confirm this and maybe even suggest an alternative solution.
VCDS
Translated on 21-08-2026, 1:15.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post18-04-2018, 6:27    Subject: Reverse Light BMW E91 320d 2005 Quote
Yes, there is a solution. I'll send you the instructions later this evening when I'm home.
See you later.
Regards, Mpire.
Translated on 21-08-2026, 1:17.
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber, chli1976, DieselBär30x and klahaui likes this.
Post18-04-2018, 19:00    Subject: Reverse Light BMW E91 320d 2005 Quote
Hi there,
Okay, you definitely need the EDIABAS program with the INPA tools to read the error memory and Tools32 to reset the short circuit counter. The error memory can only be cleared after a successful reset. Also, the fault/short circuit should already be fixed icon_wink.gif.
Within the BMW community, many users of EDIABAS software offer their assistance regionally, so you may not necessarily need to obtain the software yourself.
Selecting the correct control unit, which varies depending on the vehicle model, is usually easiest when you read the error memory.
Then, as follows:
- Open Tools32 (C:\EDIABAS\Tools32.exe).
- F3
- FRM_87.prg (for FRM1) or
- Open the file "FRM_70.prg" (for FRM2/FRM3).
- Execute job "STATUS_LAMPEN_KURZSCHLUSS_COUNTER" by double-clicking it.
- In the results window, find the value that is 50 (this should represent the lamps that are no longer working).
- Job "_RESET_KURZSCHLUSS_SPERRE" (FRM_87.prg = FRM1)
- Job "TAXES_RESET_SHORT_CIRCUIT_SHUTDOWN" (FRM_70.prg = FRM2/3)
Search and specify the lamp number as an argument, indicating which counter should be reset (the corresponding lamp number can be found in the "LampNrTexte" table).
Exit the control unit menu, turn off the ignition, wait briefly, then turn the ignition back on – you're done.
Note: If you find nothing wrong with the wiring and taillight, the light switch is usually the most likely culprit for a short circuit.
Regards, Mpire.
Translated on 21-08-2026, 1:20.
chli1976
Post18-04-2018, 20:04    Subject: Reverse Light BMW E91 320d 2005 Quote
Thank you for the instructions.
VCDS
Translated on 21-08-2026, 1:22.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Deals: Top 1/3 Products for 2005 On-Board Diagnostics (OBD)
No new posts Best Deals 2/3 for 2005 On-Board Diagnostics (OBD)
No new posts Deals: Top 3 Products for 2005 On-Board Diagnostics (OBD)
No new posts Altea 2.0 FSI: Specs & Info for 2005 Model Gasoline Engine Technology
