VW Touran Turbo Sensor: Faulty or Inaccurate?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post20-04-2018, 18:07    Subject: VW Touran Turbo Sensor: Faulty or Inaccurate? Quote
Evening.
I have a VW Touran 1T that occasionally throws an error. The glow plug indicator light illuminates on the instrument cluster, and the display shows "Engine Malfunction."
I've already replaced the boost pressure sensor twice, and then it lasted for about 6 months each time.
The wiring appears to be okay, with no signs of chafing or similar issues.
Do you have any suggestions for me about what else I could do?
Thilo
Log-V-R40-WVGZZZ1TZ7W067199-188610km.txt
 File name:  Log-V-R40-WVGZZZ1TZ7W067199-188610km.txt
 File size:  12.65 KB
 Downloaded:  388 times
Translated on 28-07-2026, 14:18.
Post20-04-2018, 19:55    Subject: VW Touran Turbo Sensor: Faulty or Inaccurate? Quote
Is the mass airflow sensor stable and not malfunctioning?
The problem can only be caused by the sensor itself, its wiring, or the motor control unit.
Translated on 28-07-2026, 14:19.
New posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kompressionsmessung unplausibel Diesel Engine Technology
No new posts CFGB mass flow meter - readings are implausible Diesel Engine Technology
No new posts Abgastemp. vor Partikelfilter unplausibel, Audi BRE Diesel Engine Technology
No new posts Boost Sensor in ECU? Diesel Engine Technology
