neue Nockenwelle nach kurzer Zeit wieder eingelaufen. | Posts 16+
Go to page: Previous  1, 2
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber likes this.
Post30-04-2018, 10:20    Subject: Quote
At the circled location, the supply bore emerges from the engine block, directly from the main channel.
The oil flows through the small opening/channel into the annular space between the bolt and the bore. In the upper part of the bore, another hole extends laterally into the main channel of the cylinder head.
So, if you want to check the oil flow/passage, you must start from that single borehole.
You can build an adapter that seals the screw holes at the top and bottom, as well as the small groove in the sealing surface, but then has a connection at the bottom for air/oil, etc., to allow pressure to be applied.
Regards, Mpire.
Translated on 13-09-2026, 7:19.
Post30-04-2018, 12:05    Subject: Quote
@ucap: Please don't just grab random images from the web and upload them!
It's very annoying; now Mpire has wasted their effort for nothing. icon_confused.gif
Translated on 13-09-2026, 7:20.
ucap
Post30-04-2018, 14:28    Subject: Quote
You can create an adapter that seals the screw holes at the top and bottom, as well as the small groove in the sealing surface, but then has a connection at the bottom for air/oil, etc., to allow pressure to be applied.
Greetings Mpire.
Hello, I'm afraid I don't quite understand what you mean. Which holes are you referring to? Does the oil flow directly up through the screw holes? Or does it flow through the holes next to them and then over the screw holes into the channels?
Translated on 13-09-2026, 7:21.
ucap
Post30-04-2018, 18:17    Subject: Quote
Can someone explain this to me based on the pictures of my cylinder head?
 File size:  889.12 KB
 Viewed:  351 times
Translated on 13-09-2026, 7:22.
ucap
Post30-04-2018, 18:36    Subject: Quote
There's a small branch connected to this screw hole with the groove. But otherwise, I can't find any other lines.
 File name:  EF1120FB-8F05-4F41-B49E-296360CD0D96.jpeg
 File size:  2.71 MB
 Downloaded:  256 times
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post30-04-2018, 20:08    Subject: Quote
In the area of the circle, the oil comes from the block, travels along the head bolt upwards, and from there supplies the main channel in the head. There must be a branch-off in this bore. icon_wink.gif
There's no other way to do it, and it was the same back in 1972 with the EA827 at the same location, using the same principle, and it still works that way today.
Regards, Mpire.
 File name:  Ölfluß.jpeg
 File size:  1.99 MB
 Downloaded:  280 times
Translated on 13-09-2026, 7:23.
ucap
Post30-04-2018, 21:37    Subject: Quote
In the area of the circle, the oil comes from the block, travels along the head bolt upwards, and from there supplies the main channel in the head. icon_wink.gif There must be a branch in this bore.
Greetings Mpire.
Okay, I found the junction. However, I can't get a wire into it. Does anyone have a trick for how I could clean out the channel?
Translated on 13-09-2026, 7:24.
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Nockenwelle eingelaufen, Hydros durchgeschlagen Diesel Engine Technology
No new posts Camshaft Worn or Lifters? Metal in Oil Filter Diesel Engine Technology
No new posts Reactivate tax device after prolonged power outage On-Board Diagnostics (OBD)
No new posts New camshaft with signs of wear after 450 km Diesel Engine Technology
