Clean AGR Valve Without Removal
vag-driver
Post02-05-2018, 9:47    Subject: Clean AGR Valve Without Removal Quote
Are there any positive experiences with additives like Mathy AGR cleaner?
I searched in vain for an official proof of its efficiency.
Andreas
Translated on 14-10-2026, 2:13.
Post02-05-2018, 11:12    Subject: Clean AGR Valve Without Removal Quote
Hello Andreas,
"All the AGR systems I've heard about that were described as 'defective' had mechanical problems. Therefore, I wouldn't expect too much, even if there were any significant cleaning effect at all. I simply can't imagine how a heavily carbonized sludge could be removed in a short time without mechanical action or the harsh side effects of aggressive chemicals."
A clogged EGR valve would be indicated by the actual mass airflow values. You can identify this in a mass airflow log by observing that, even though the EGR valve duty cycle is at its maximum, the actual mass airflow value is still slightly higher than the target value.
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Clean DPF Without Removal: Easy Guide Diesel Engine Technology
No new posts Intake Valve Cleaning: Remove Carbon Build-up? Diesel Engine Technology
No new posts Can the VP37 distribution body be removed without disasse... Diesel Engine Technology
No new posts Wheel bearing tool Hazet 4930, no strut removal required? Transmission, Chassis, Body & Interior
