Undergrkg87
11-05-2018, 18:57 Subject: Access permission, radial dampening |
Hello!
I want to adjust the vehicle's ride height after lowering it and need the login code for the suspension system to do so.
Does anyone have this? And...
Have a great weekend!!!
| Description: |
 Download |
| File name: |
Scan-WAUZZZ8V0F1023411-20180511-1719-43504km.txt |
| File size: |
19.21 KB |
| Downloaded: |
493 times |
Herbert Profi-Schrauber
11-05-2018, 19:33 Subject: Access permission, radial dampening |
Sure, I can translate the text from German to English. Please provide the text you would like me to translate.
Detective work is tedious.
Undergrkg87
11-05-2018, 19:39 Subject: Access permission, radial dampening |
I thought it would be obvious in the car scan  .
It would be an Audi S3 8V, model year 2014.
Sherlock
11-05-2018, 20:28 Subject: Access permission, radial dampening |
Much better. If you want something, you should clearly state what it is.
Joined: 04/12/2002 Posts: 18086 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
12-05-2018, 9:06 Subject: Access permission, radial dampening |
Hello Undergrkg87,
What function in the VCDS control unit overview corresponds to the wheel damping control unit?
There are several things that, depending on the control unit, could function as a login, and I suspect that simply hovering the mouse cursor over the corresponding input field and waiting didn't work?
Profile PM WWW Garage |
Undergrkg87
12-05-2018, 15:08 Subject: Access permission, radial dampening |
Hello Rainer!
It concerns the function "Wheel damping: Adjust height values for each wheel." Unfortunately, it requires a login after changing the values in the customization channel.
Unfortunately, the usual speech bubble and login functionality are not working.
Best regards, Mario.
12-05-2018, 18:27 Subject: Access permission, radial dampening |
Again, what "login" functionality does the control unit offer?
Undergrkg87
14-05-2018, 17:56 Subject: Access permission, radial dampening |
Hello Rainer,
I don't quite understand which login function you're referring to.
Are there multiple  ?
I specifically bought a repair manual for the chassis, hoping to gain access, but did you think
14-05-2018, 18:18 Subject: Access permission, radial dampening |
Please post a Screenshot of the control unit information for the relevant control unit.
Undergrkg87
14-05-2018, 20:08 Subject: Access permission, radial dampening |
Here is the information about the control units.
Is there a way to access the labels again now?
Do you want to open files?
Thank you very much.
| Description: |
 Download |
| File name: |
Log-WAUZZZ8V0F1023411.txt |
| File size: |
1.73 KB |
| Downloaded: |
293 times |
14-05-2018, 20:16 Subject: Access permission, radial dampening |
dieselschrauber wrote: | Please post a Screenshot of the control unit information for the control unit in question.
Best regards, Rainer |
Undergrkg87
14-05-2018, 20:29 Subject: Access permission, radial dampening |
Sure.
| Description: |
| File size: |
9.15 MB |
| Viewed: |
698 times |
14-05-2018, 21:53 Subject: Access permission, radial dampening |
Yes, instead of the "Access Permission - 16" button, there are other options available depending on the specific control unit.
I found something, but I'm not sure if it's a good idea to post it publicly (for safety reasons), because an incorrect attitude can affect driving safety.
Therefore, please contact support at ross-tech.com directly in this case and explain what you intend to do.
Sure, you can refer to this topic as well.
Undergrkg87
15-05-2018, 17:48 Subject: Access permission, radial dampening |
Okay.
Thank you, Rainer, for the information.
I'll write to Ros about it.
Greetings from the Allgäu region.
hadez16
06-06-2018, 11:53 Subject: Access permission, radial dampening |
The procedure is not yet possible with VCDS.
Only ODIS.
