EDC15: AEL/ACV/AJT Engine - ELAB Not Opening
T3SyncroTDI
Post20-06-2018, 9:55    Subject: EDC15: AEL/ACV/AJT Engine - ELAB Not Opening Quote
So far, I have only been a silent reader here, but now I have a problem that I would like to bother you with... icon_wink.gif
I have combined an AEL engine from a Volvo V70 with a wiring harness and an EDC15 engine control unit from an ACV/AJT engine from a T4. Both engine control units (ACV/AJT) are present, and the immobilizer has been disabled. How and with what tools can I re-check something? Before disabling the immobilizer, I had the error 'Engine control unit locked.' That error has now disappeared.
The error log contains only one entry: the control unit cannot communicate with the speedometer via the CAN bus. This is because the CAN bus is not connected.
Everything seems to be correctly wired electrically. I've transferred sensors like the mass airflow sensor (MAF), manifold absolute pressure (MAP) sensor, throttle pedal, etc., from the T4. The ESP system is from AEL, and the connector on the wiring harness has been changed to a Volvo/AEL type.
When the ignition is turned on, the control unit opens the ELAB (electric latching actuator) for approximately 3 seconds, then closes it again. During the actuator diagnosis, the ELAB does not click. When 12V is manually applied to the ELAB, it clicks. The ELAB behaves the same way with both control units.
As a diagnostic tool, I use an old laptop from an Audi workshop, along with their software and a wireless dongle.
I would definitely be open to a different/better system...
I would be grateful for any tips on how to proceed with troubleshooting!
Best regards, Sönke.
Translated on 27-09-2026, 9:22.
Post20-06-2018, 10:50    Subject: EDC15: AEL/ACV/AJT Engine - ELAB Not Opening Quote
Hello Sönke,
The following options are available:
We cordially invite you to participate. The requirement for posting in diagnosis-related topics (everything for which a vehicle diagnostic system is needed) is...
If the conditions are met, an automated scan would be initiated.
Translated on 27-09-2026, 9:25.
No new posts Roomster Tailgate Won't Open: Remote Button Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Door Auto Open/Close Problem (8L) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU differences: EDC15 vs. EDC15+ On-Board Diagnostics (OBD)
No new posts AGR valve not being activated, Audi A2 1.2 TDI EDC15 Diesel Engine Technology
No new posts A3 8P: Central Locking Not Working with Key On-Board Diagnostics (OBD)
No new posts Central Locking: Rear Doors Won't Open? Electrical Systems, Vehicle Electronics, Multimedia
