U0212 Error: No Communication Possible
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Lochhaas123
Post27-01-2018, 20:32    Subject: U0212 Error: No Communication Possible Quote
"For the past few days, my 2016 Toledo with a 1.6 TDI engine has been acting up. The car is locked and everything is supposed to be off. However, after a few hours, the radio turns on by itself and stays on. Similarly, the headlights turn on from time to time without anyone doing anything. I hope someone can help me."
Saturday, January 27, 2018, 17:40:20:18499
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 7 x86.
VCDS Version: RKS 17.8.0.1
Data as of: 20170817 DS276.4
Vehicle Identification Number: VSSZZZNHZG1008320
License plate:
Mileage: 37369 km. Repair order: Father.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: NH-SK25 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 55 5F
Mileage: 37,369 km
01-Motor electronics -- Status: Error 0010.
03-Brake electronics -- Status: Error 0010.
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
10-Parking assist 2 -- Status: Error 0010.
15-Airbag -- Status: Error 0010.
17-Circuit breaker panel insert -- Status: Error 0010.
19-pin diagnostic interface -- Status: Error 0010.
44-Steering Assist -- Status: Error 0010.
55-Beam adjustment. -- Status: Error 0010.
5F-Information Selection. I -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine Control Module (J623-CXMA)
Label file: .DRV\04L-907-309-V1.clb
Part number SW: 04L 906 021 EG
Part number HW: 04L 907 309 E
Component: R4 1.6L EDC H22 1746
Revision: 86H22---
Encoding: 01110032032401090000
Operating number: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI01104L906021EG 001005
ROD: EV_ECM16TDI01104L906021EG_SK25.rod
VCID: 6ED7B786B1DF463668-803A
3 error codes found:
25011 - Door control unit, driver's side.
U0199 00 [032] - No communication.
Sporadic - unconfirmed - checked since last deletion.
4714 - Control unit for steering column electronics.
U0212 00 [032] - No communication.
Environmental conditions:
Error status: 00000001
Error priority: 6
Error frequency: 1
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:00
Motor speed: 2090.50 rpm.
Normalized load value: 64.7%
Vehicle speed: 57 km/h
Coolant temperature: 90 °C.
Intake air temperature: 80 °C
Atmospheric pressure: 970 mbar.
Voltage at terminal 30: 14.980 V.
Lost learning counter via OBD: 40.
Limit: Accelerator pedal: 140.2 Nm.
CAN Status - Engine Control Unit Bit 0: 0
Speed control system: Status bit 0: 0.
CAN Status - Transmission Control Unit Bit 0: 0
CAN Status - Brake Control Unit: 1-bit 0: 0.
CAN Status - Brake Control Unit: 2-bit, Value: 0.
Embedded gear-tooth bit 0: 3
4720 - Body Computer 2 / Comfort System
U0141 00 [032] - No communication.
Error priority: 6
Error frequency: 1
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:01
Motor speed: 2125.00 rpm.
Normalized load value: 83.1%
Vehicle speed: 58 km/h
Intake air temperature: 81 °C
Limit: Accelerator pedal: 191.4 Nm.
Speed control system: Status bit 0: 7.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics (J104)
Label file: Bypass active! (or: Routing error!)
Part number SW: 6R0 614 517 BQ. Part number HW: 6R0 614 517 BQ.
Component: EBC 460 ESP H52 0001
Serial number: A00UC1X
Encoding: 43F84876897E00DBC226122C91220079170900C1
Operating number: WSC 73430 031 00063
ASAM Dataset: EV_Brake1ESCEBC460PQ26L 003014
ROD: EV_Brake1ESCEBC460PQ26L_003.rod
VCID: 0301F6328A5D5B5E97-8056
2 error codes found:
0526 - Data bus, missing message.
U1121 00 [008] - -
Sporadically - confirmed - checked since last deletion.
Error priority: 6
Error frequency: 1
Lost Count: 148
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:01
Error code: 00 02 0E
0459 - Tire pressure warning.
C102D 00 [136] - -
Warning light ON - Intermittent - Confirmed - Checked since last reset.
Error priority: 4
Error frequency: 1
Lost Count: 198
Mileage: 33,095 km
Date: 2017.10.09
Time: 17:03:20
Error code: 00 01 CB
Address 08: Climate Control/Heating Unit (J255)
Label file: | 6C0-907-044.clb
Part number SW: 6P0 907 044 A, Hardware: 6P0 907 044 A.
Component: Climatronic H01 0201
Serial number: 1506141A-0174
Encoding: 011000001011000201
ASAM Dataset: EV_ACClimaValeoPQ26 003001
FILE: EV_ACClimaValeoPQ26.rod
VCID: 2F696A8276550F3E23-807A
459014 - Data bus: Missing message.
U1121 00 [012] - -
Error priority: 6
Error frequency: 1
Lost Count: 148
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:01
1048834 - Functionality limitation due to power management.
B10CD 00 [008] - -
Error priority: 7
Error frequency: 24
Lost Count: 133
Mileage: 33910 km
Date: 2017.11.05
Time: 17:28:01
Voltage at terminal 30: 14.5 V.
Auxiliary heating: multi-stage activation; enable auxiliary heating: no_enabling.
Auxiliary heating: stepped, setpoint value: 0.
Auxiliary heating: stepped setpoint: 3.
Auxiliary heating: Control system setpoint level: 0.
Address 09: Central Electronics (J519)
Label file: | 6C0-937-089-V1.clb
Part number SW: 6C0 937 089 C, HW: 6C0 937 089 C.
Component: BCM PQ26 Hi4R H08 0084
Serial number: 001378007428
Encoding: 0800085042150AFB43804000402F070800015900530A350000000000000000
Operating number: WSC 73430 790 00000
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005_SK25.rod
VCID: 306B69FE6B6B10C63A-8064
Rain and light sensor:
Subsystem 1 - Part number SW: 5Q0 955 547 A, HW: 5Q0 955 547 A, Label file: DRV\5Q0-955-547.CLB.
Part number: RLHS 037 0059.
Serial number: S4Y15M06D22H18M53S15.
Encoding: 00185E
Driver's side door control unit:
Subsystem 2 - Part number SW: 6V1 959 801 B, HW: 6V1 959 801 B.
Component: FHSG DRV 007 0001
Serial number: 00000000000001599797
Encoding: 011200
Humidity sensor: internal:
135688 - Terminal S
B11A5 12 [008] - Short circuit to positive.
Error priority: 6
Error frequency: 1
Lost Count: 146
Mileage: 37,317 km
Date: 2018.01.26
Time: 18:57:14
919560 - Light switch.
B126A 29 [008] - implausible signal.
Error priority: 3.
Error frequency: 35.
Lost Count: 150
Mileage: 37251 km
Date: 2018.01.25
Time: 16:55:17
Address 10: Parking Assist 2 (J791) Label file: | DRV\5Q0-919-283.clb
Part number SW: 5Q0 919 283 D, HW: 5Q0 919 283 D.
Component: PARKING ASSIST 3K H10 0048
Revision: -------- Serial Number: 39291516108427
Encoding: 0001050001
ASAM Dataset: EV_EPHVA14AU3700000 002022
ROD: EV_EPHVA14AU3700000_002_SK37.rod
VCID: 3A7F4BD6BD17DA9684-806E
"One error found:"
12665088 - Data bus: missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 148
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:00
Address 15: Airbag (J234)
Label file: |6C0-959-655.clb|
Part number SW: 6C0 959 655 G, HW: 6C0 959 655 G.
Part number: VW20Airbag807 001 0360
Revision: -------- Serial Number: 003RK0005HWI
Encoding: 88CCC00000800000540000C8002800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 377952E28E05C7FE7B-8062
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 442 151 906 15
Component: SideSensor_Df, Part Number: 1CA 0148.
Serial number: 3497A009F1B6A755831S
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: ----------- HW: 442 152 206 15
Component: SideSensor_Pf 1CA 0148
Serial number: 3507A00C51ACFCF3744$
Encoding: 2D2D2D
Crash sensor for rear side airbag, driver's side.
Subsystem 3 - Part number: SW: ----------- HW: 442 151 906 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00C91AC53B0A1DR
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 442 152 206 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C51ACFCF3531Z
Encoding: 2D2D2D
"One error found:"
1054208 - Data bus: missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 148
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:01
Address 17: Control panel module (J285)
Label file: | DRV\5K0-920-xxx-17.clb
Part number SW: 6JA 920 741 G, HW: 6JA 920 741 G.
Part: COMBINATION INSTRUMENT 205 1421
Encoding: 072404002980000801086A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 3F893AC2A635FFBEB3-806A
16776964 - Data bus: missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 148
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:01
9456433 - Key
B104B 31 [008] - No signal.
Error priority: 1
Error frequency: 5
Lost Count: 150
Mileage: 37,310 km
Date: 2018.01.25
Time: 22:17:56
Address 19: Diagnostic Interface (J533)
Label file: | DRV\6C0-909-901-V1.clb
Part number SW: 6C0 909 901 Part number HW: 6C0 937 089
Component: GW MQB A0 H08 0084
Revision: -------- Serial Number: 001378007428
Encoding: 030100044F005A00000000000000010001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_SK25.rod
VCID: 65C5C8AA6429856E19-8030
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 5F0 959 537 B, HW: 5F0 959 537 B, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B0961290415
Encoding: 002000
Battery monitoring control unit:
Subsystem 2 - Part number SW: 6C0 915 181, HW: 6C0 915 181.
Component: J367-BDM H08 0223
Serial number: 52154724574351165837.
"One error found:"
131654 - Climate control unit.
U0164 00 [008] - No communication.
Error priority: 2
Error frequency: 1
Lost Count: 145
Mileage: 37,310 km
Date: 2018.01.25
Time: 22:32:56
Supply voltage, terminal 30: 12.1 V.
Terminal 15: disconnected.
Address 44: Steering Assist (J792)
Label file: | DRV\6Rx-909-144-V2.clb
Part number SW: 6C1 909 144 AG, Part number HW: 6C1 909 144 D.
Part: EPS_TRW_ALow 312 3232
Serial number: CF6O1045.
Encoding: 000700
Operating number: WSC 73430 790 00063
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6DD5B08ABCD9BD2E51-8038
1063424 - Data bus: missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 148
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:01
Motor speed: 2152 RPM.
Vehicle speed: 58.91 km/h
System status: Operational.
Status Terminal 15: Terminal 15 is active.
Voltage at terminal 30: 14.79 V.
Power consumption of the steering assist: 0.49 A.
Power consumption of the steering assist: 30.35 A.
Final temperature: 20 °C
Power steering: Motor power: 100%.
Crankshaft position sensor: 334°.
Motor position feedback: -3 /min.
Power steering: Motor torque request: -0.04 Nm.
Torque: 0.07 Nm
Steering torque: OK.
1052160 - Data bus: missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 148
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:01
Motor speed: 2125 RPM.
Vehicle speed: 58.31 km/h
Voltage at terminal 30: 14.82 V.
Power consumption of the steering assist: 0.50 A.
Crankshaft position sensor: 338°.
Motor position feedback: -4 /min.
Power steering: Motor torque request: -0.01 Nm.
Torque: 0.30 Nm
Address 55: Headlight range control (J431) Label file: | DRV\5Q0-907-357.clb
Part number SW: 5Q0 907 357, HW: 6R0 907 357 A.
Component: LWR-ECU 005 0080
Revision: -------- Serial Number: --------------
Encoding: 02CA000009000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: 75E598EAD48975EEA9-8020
"One error found:"
13705481 - Data bus, missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 148
Mileage: 37,338 km
Date: 2018.01.27
Time: 13:00:00
Address 5F: Information Selection Register I (J794)
Label file: | DRV\5F0-035-MIB-STD2.clb
Part number SW: 5QA 035 846 Hardware: 5QA 035 846
Component: MU-S-N-ER H24 0241
Serial number: SEZAZ2R0197632.
Encoding: 04520101BE00000011110001000808002F0200C401200100C6
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_SK25.rod
VCID: 010DFC3A9041494E85-8054
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 5F0 919 604 A, HW: 5F0 919 604 A.
Component: ABTm_Std2_Nav H43 1028
Serial number: SEZ8Z9RFT001M1
Storage media:
Subsystem 2 - Part number SW: 6P0 919 866 HW: -----------
Component: ECE 2015/16 --- 0430
Serial number: --------------------
No error codes found.
Translated on 15-10-2026, 14:31.
Post27-01-2018, 22:40    Subject: U0212 Error: No Communication Possible Quote
Hallo, da fÀllt mir nur ein... Water damage?
Lochhaas123
Post27-01-2018, 22:52    Subject: U0212 Error: No Communication Possible Quote
"Just wondering where and what to look for. The vehicle appears to be in good condition overall. Are there any specific areas I should pay close attention to?"
vag-driver
dieselschrauber likes this.
Post28-01-2018, 10:14    Subject: U0212 Error: No Communication Possible Quote
I would first check if the carpets are wet or damp. That would be the first indication of a water leak.
Once, I experienced a similar issue with my Audi. It was quite cold (-8°C) and windy. The car had been parked outside for a few days. Suddenly, the low beam headlights turned on by themselves. The taillights were off. The only thing that worked was to start the engine briefly and then turn it off. There were no error codes stored in the system.
Dieses Verhalten ist ungefÀhr 2 bis 3 mal aufgetreten. Never again after that.
You might be able to identify recurring, external factors that contribute to the occurrence of the error.
Viele GrĂŒĂŸe
Andreas
*** Ein Ingenieur muss vordenken. Wenn er anfÀngt nachzudenken ist es schon zu spÀt. ***
Translated on 15-10-2026, 14:32.
Lochhaas123
Post28-01-2018, 18:08    Subject: U0212 Error: No Communication Possible Quote
The carpets are dry. The only thing I noticed is that the light switch flickers when it's in the "auto" position. After clearing the error memory, only the problem with the light switch remains.
Translated on 15-10-2026, 14:33.
Post28-01-2018, 19:19    Subject: U0212 Error: No Communication Possible Quote
Lochhaas123 wrote:
The carpets are dry. The only thing I noticed is that the light switch, when set to "Auto," is flickering. After clearing the error memory, only the error related to the light switch remains.
Perhaps the light switch is the culprit, with internal electrical connections where they shouldn't be? Or maybe the vehicle's onboard computer is malfunctioning, and the glowing light switch is just a symptom...
Translated on 15-10-2026, 14:34.
vag-driver
Post28-01-2018, 22:13    Subject: U0212 Error: No Communication Possible Quote
Does the electrical appliance still run even when the light switch is in the OFF position?
Viele GrĂŒĂŸe
Andreas
Translated on 15-10-2026, 14:35.
brezelmann01
Post28-01-2018, 22:27    Subject: U0212 Error: No Communication Possible Quote
I would definitely take a look at the "S contact error." For me, that seems more likely to be the cause of the problem than the light switch. The light might be an emergency light because the "S contact" is malfunctioning, and the other control units are not accessible.
Brezelmann01
[VERKAUFT] Polo 6NF 1.4TDI (AMF) mit nachgerĂŒstetem DPF, STH+FFB, Bj. 2000, 222tkm
Translated on 15-10-2026, 14:36.
Lochhaas123
Post28-01-2018, 22:56    Subject: U0212 Error: No Communication Possible Quote
How do I check the contact? The problem is that it only happens intermittently. What's strange is that the light switch in the car sometimes flickers.
brezelmann01
Post29-01-2018, 22:06    Subject: U0212 Error: No Communication Possible Quote
First, I would check the relevant measuring blocks for the terminals in VCDS and see what they show. Perhaps something can be identified there.
Translated on 15-10-2026, 14:37.
Lochhaas123
Post24-06-2018, 22:32    Subject: New Defects: Common Problems and Solutions Quote
"Good day, I tried swapping the light switch with one from a similar vehicle as a test, but unfortunately, it didn't work. However, the vehicle no longer has the issue of the radio turning on automatically. Instead, the central locking system is malfunctioning. The car is locking itself even when the key is still in the ignition. Additionally, the welcome and coming home lights are not working. Can anyone help me? Seat refuses to do anything under warranty, despite the car having 30,000 km (approximately 18,600 miles) on the odometer. Below is the current error log from today."
Sunday, June 24, 2018, 6:04:13 PM: 18499
License plate:
Mileage: 43665 km. Repair order: Reinhold.
Mileage: 43,665 km
03-Brake electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Revision: 86H22---
4 error codes found:
17167 - Received error value on the data bus.
U1123 00 [032] - -
Error priority: 6
Error frequency: 1
Mileage: 43,114 km
Date: 2018.06.13
Time: 11:09:51
Motor speed: 1226.00 rpm.
Normalized load value: 1.2 %
Vehicle speed: 65 km/h
Intake air temperature: 72 °C
Atmospheric pressure: 960 millibars.
Voltage at terminal 30: 12.240 V.
Lost count after OBD: 11
Powertrain Coordinator: ACC Fault Status Bit 0: 0
Powertrain Coordinator: ACC fault status bit 8: 0.
Drive system coordinator: Brake fault status bit 0: 0.
Powertrain Coordinator: Brake Function Status Bit 0: 0
Powertrain Coordinator: Brake Function Status Bit 8: 0
Acceleration: -0.230 m/sÂČ
Error priority: 6
Error frequency: 1
Mileage: 43,110 km
Date: 2018.06.13
Time: 11:07:36
Motor speed: 2961.00 rpm
Normalized load value: 76.9%
Vehicle speed: 81 km/h
Intake air temperature: 108 °C
Voltage at terminal 30: 14.860 V.
Limit: Accelerator pedal: 231.0 Nm.
Speed control system: Status bit 0: 2.
Error priority: 6
Error frequency: 1
Mileage: 43,110 km
Date: 2018.06.13
Time: 11:07:36
Motor speed: 3017.00 rpm.
Normalized load value: 77.3%
Vehicle speed: 82 km/h
Coolant temperature: 91 °C
Intake air temperature: 109 °C
Voltage at terminal 30: 14,900 V.
Limit: Accelerator pedal: 227.9 Nm.
"One error found:"
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 167
Mileage: 43,110 km
Date: 2018.06.13
Time: 11:07:36
"One error found:"
1179905 - Enclosure fan.
B126B 01 [012] - Electrical fault.
Error priority: 2
Error frequency: 1
Lost Count: 191
Mileage: 43571 km
Date: 2018.06.22
Time: 15:10:36
Voltage at terminal 30: 14.6 V.
Encoding: 00185E
Encoding: 011200
"One error found:"
Error priority: 3.
Lost Count: 14
Mileage: 37,675 km
Date: 2018.02.05
Time: 21:29:26
"One error found:"
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 167
Mileage: 43,110 km
Date: 2018.06.13
Time: 11:07:35
Encoding: 2D2D2D
Encoding: 2D2D2D
Encoding: 2D2D2D
Encoding: 2D2D2D
"One error found:"
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 167
Mileage: 1,048,574 km
Date: 2000.00.00
Time: 00:00:00
Address 17: Control unit interface (J285)
Address 19: Diagnostic interface (J533)
Encoding: 002000
Encoding: 000700
"One error found:"
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 167
Mileage: 43,110 km
Date: 2018.06.13
Time: 11:07:36
Motor speed: 3021 RPM.
Vehicle speed: 82.88 km/h
Voltage at terminal 30: 14.76 V.
Power consumption of the steering assist: 0.74 A.
Power consumption of the steering assist: 53.15 A.
Final temperature: 37 °C.
Motor position sensor: 7°.
Motor position feedback: -6 /min.
Power steering: Motor torque request: -0.23 Nm.
Torque: -2.17 Nm
"One error found:"
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 167
Mileage: 43,110 km
Date: 2018.06.13
Time: 11:07:35
End----------------------------(Duration: 02:50)-----------------------------
Translated on 15-10-2026, 15:12.
Post25-06-2018, 8:02    Subject: U0212 Error: No Communication Possible Quote
The numerous missing messages in the error scan, along with the slightly too-high voltage reading in the vehicle scan at the beginning of the topic, suggest potential problems with the vehicle's power supply.
Are the connections to the battery properly tightened? Do you have the possibility to test the battery by swapping it with one from another vehicle? Have you checked all the fuses in the vehicle for signs of damage or corrosion?
Do you have an oscilloscope to check the on-board voltage? If not, I would at least look at the measurement blocks of a control unit, preferably those that are causing problems, such as the on-board network control unit, and see how the on-board voltage reacts to changes in load, doors slamming, etc.
Translated on 15-10-2026, 15:13.
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.8L V6 AAH - No communication On-Board Diagnostics (OBD)
No new posts Passat 3b5 keine Kommunikation ABS-Schalttafeleinsatz On-Board Diagnostics (OBD)
No new posts ACC/PDC Failure: No Communication - Troubleshooting Electrical Systems, Vehicle Electronics, Multimedia
No new posts Skoda Octavia: No Radio Communication? On-Board Diagnostics (OBD)
