reuselkopp Blaumann
30-07-2018, 8:18 Subject: What adhesive should be used to glue a turbocharger boost hose? |
Hello everyone,
I'd like some advice or a tip from you. We have a Smart CDI in our family's fleet of vehicles. The Smart keeps leaking oil from the connection between the turbocharger pressure hose and the mixer housing, towards the oil cooler. The connection is a peculiar type of connector that is often used by VAG (Volkswagen Group). Unfortunately, a completely new hose hasn't improved the situation. Wrapping the connector with tape also didn't help. I remember reading something about gluing it in this forum, but I can't find the thread anymore. What kind of adhesive or sealant can I use here?
Thank you and best regards.
Reuselkopp. Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 05-07-2026, 22:47.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
30-07-2018, 8:52 Subject: What adhesive should be used to glue a turbocharger boost hose? |
Oil-/fuel-resistant silicone?
Translated on 05-07-2026, 22:48.
Profile PM WWW Garage |
reuselkopp Blaumann
30-07-2018, 10:10 Subject: What adhesive should be used to glue a turbocharger boost hose? |
Hello Rainer,
Thank you for your tip. I just ordered Mannol 9912, which should work.
Translated on 05-07-2026, 22:49.
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
01-08-2018, 13:11 Subject: What adhesive should be used to glue a turbocharger boost hose? |
Hello reuselkopp.
"Back then, in the 11th grade, I used a silicone tube from a hardware store (and documented it here in a thread). It worked very well." I cannot say how easy or difficult the disassembly would be.
I am unable to translate "haithamina" because it does not appear to be a word or phrase in the German language. It may be a misspelling, a proper noun, or a term from a specialized field. If you can provide more context or clarify the intended meaning, I would be happy to assist you with the translation. 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
