AFN won't start: Troubleshooting guide (27-10-2003, 15:52)
Cheffe
Post27-10-2003, 15:52    Subject: AFN won't start: Troubleshooting guide Quote
I'm having a problem with a Passat from 1997, engine code: AFN. It stalled while driving. Initially, it didn't respond to the accelerator and then it shut off. I suspect the issue is related to the fuel supply.
No error codes are present, and the fuses and relays are in good condition. The diesel filter was recently replaced.
The search function didn't really yield any useful results.
Does anyone have any advice?
Boss.
Translated on 21-08-2026, 10:41.
Albrecht
Post27-10-2003, 16:06    Subject: AFN won't start: Troubleshooting guide Quote
Could it be that it was very cold, causing the summer diesel to clog the filter?
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 21-08-2026, 10:42.
Cheffe
Post27-10-2003, 17:02    Subject: AFN won't start: Troubleshooting guide Quote
It really shouldn't be the case, as the filter was replaced about two weeks ago.
Translated on 21-08-2026, 10:43.
Post27-10-2003, 17:53    Subject: AFN won't start: Troubleshooting guide Quote
HI,
I would still like to disconnect the return line of the pump at the filter and try starting it briefly.
If there's no diesel fuel available, you know where to look...
And even a brand new filter can quickly become clogged due to summer diesel fuel that contains sulfur icon_wink.gif.
christians
Post27-10-2003, 20:39    Subject: AFN won't start: Troubleshooting guide Quote
Stupid question:
Is the timing belt still in good condition?
Gruß Christian
Translated on 21-08-2026, 10:44.
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car won't start, lights not working Diesel Engine Technology
No new posts VW TDI V10 won't start Diesel Engine Technology
No new posts A6 5-cylinder. TDI won't start Diesel Engine Technology
No new posts AFN springt nicht an Diesel Engine Technology
