ECU Versions: Engine Control Unit Software
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post06-08-2018, 13:50    Subject: ECU Versions: Engine Control Unit Software Quote
Hello fellow DIY enthusiasts,
Can anyone provide me with information about the hardware components used in engine control units (ECUs) within a specific model series?
Specifically, this would be:
EDC 15 VM+2.V1
e.g., VW 074 906 018 AJ or Bosch 0281010461.
compatible with VW 065 906 018 or Bosch 0281010710.
Specifically, I would like to know if the multi-connector for the engine control unit has different versions or configurations.
Are the multi-connectors the same within a series, for example, are the two MSG connectors mentioned above (EDC 15 VM+2.V1) identical?
Translated on 14-10-2026, 1:35.
Post06-08-2018, 19:50    Subject: ECU Versions: Engine Control Unit Software Quote
To the best of my knowledge, the connectors are all the same for that specific engine control unit model.
Translated on 14-10-2026, 1:36.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Trunk Lid: Different Versions Available Transmission, Chassis, Body & Interior
No new posts Engine Control Unit 1Z Diesel Engine Technology
No new posts A6 C4 TDI Engine Control Unit On-Board Diagnostics (OBD)
No new posts T5 Engine Control Unit (ECU) On-Board Diagnostics (OBD)
