BLS, BKC, AXR Crankcase: Differences & Comparison
3bAFN
Karma: +33 / -0   Thank you, like it!
Post14-08-2018, 20:12    Subject: BLS, BKC, AXR Crankcase: Differences & Comparison Quote
Can someone tell me how the engine crankcases differ?
To my knowledge, these parts are only available from VW with pistons and other components, which is why there are different part numbers.
But are the bare casings, completely devoid of features, really different from each other?
Best regards, Sören.
Translated on 11-10-2026, 13:06.
Post16-08-2018, 8:16    Subject: BLS, BKC, AXR Crankcase: Differences & Comparison Quote
The delivered engines already have an engine identification code, and in my opinion, this alone leads to different OE (Original Equipment) numbers.
3bAFN
Post16-08-2018, 18:14    Subject: BLS, BKC, AXR Crankcase: Differences & Comparison Quote
Rüdi wrote:
The delivered engines already have the engine identification letter, and based solely on that, in my opinion, different OE numbers result.
You might be partially right. However, if the internal components, specifically the pistons, are different, it's clear that the part number would also be different.
That's why my question relates to the bare engine block.
Translated on 11-10-2026, 13:07.
3bAFN
dieselschrauber and Herbert likes this.
Post22-08-2018, 23:10    Subject: BLS, BKC, AXR Crankcase: Differences & Comparison Quote
To clarify everything.
The AXR engine has the crankshaft sensor located in a different position compared to the other two engines.
The BKC engine lacks the mounting points for the AGR (Abgasrückführung) cooler from the BLS engine.
In short, a BLS crankshaft case cannot be replaced by either of the two engines mentioned.
Translated on 11-10-2026, 13:08.
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post23-08-2018, 5:17    Subject: BLS, BKC, AXR Crankcase: Differences & Comparison Quote
Es gibt Motoren mit unterschiedlichem MKB, die Kurbelgehäuse mit gleicher Tl. Have no number.
The best way to ensure compatibility is by using the parts catalog.
It's likely not the case with the three types mentioned above.
Translated on 11-10-2026, 13:09.
No new posts Differences ESP at AAZ: 028 130 107 R vs 028 130 107 K Diesel Engine Technology
No new posts 1V - Differences from JR, Differences between RA and SB Diesel Engine Technology
No new posts ZMS Differences Upload
No new posts PDE vs. 2.0 TDI: Differences Explained Diesel Engine Technology
