DPF Differenzdruck Normwerte | Posts 16+
Go to page: Previous  1, 2, 3  Next
RedR32
Avatar-RedR32
1998 Volkswagen Golf
mk20vt likes this.
Post31-01-2013, 22:09    Subject: Quote
BLS, Series, VW Caddy
DPF roughly cleaned
175000km
938.4 mbar Air pressure, Ambient temperature 12°C
up to approximately 165 mbar
LOG-01-011-067-068.CSV
 BLS, 175.000km, DPF grob gereinigt
 File name:  LOG-01-011-067-068.CSV
 File size:  5.27 KB
 Downloaded:  1578 times
reflexsilber met.
stolley
Karma: +38 / -1   Thank you, like it!
Post10-03-2014, 16:56    Subject: Quote
- BWB
- Series
- 221,000 km, Ash mass 53g
- 948mBar Ambient Pressure, 17° Intake Air Temperature
- up to 90mbar differential pressure
140310-LOG.CSV
 File name:  140310-LOG.CSV
 File size:  12.54 KB
 Downloaded:  1191 times
Hans Dampf
Karma: +9 / -0   Thank you, like it!
2013 Ford Galaxy
Post11-07-2014, 11:16    Subject: Quote
Passat 3C
MKB: BMP
Series (according to statement)
138367 km
Ambient air pressure: 979.2 mbar
Suction pipe temperature: 42.3°C
Coolant temperature: 86.4°C
Fuel temp: 64.8 °C
 File size:  2.73 KB
 Downloaded:  1283 times
Audi A4 AKE
Post23-10-2014, 10:07    Subject: Quote
Full throttle log before DPF cleaning
Odometer: 249360 km
Ambient Pressure: 999.6 mbar // Outdoor Temp: 16 °C // Suction Pipe Temp: 27.5°C
Ash mass: 63g
Max. Differential Pressure in the Particulate Filter: 323 mbar @ 4200 rpm
 Differenzdruck mit KDataScope angezeigt, es wird der maximal messbare Differenzdruck überschritten, der Wert verharrt auf dem Maximalwert (323mbar).
 File size:  171.75 KB
 Viewed:  38434 times
 Vollgaslogs Differenzdruck, Motorkennbuchstabe BRE
 File size:  48.77 KB
 Downloaded:  1010 times
Post23-10-2014, 15:33    Subject: Quote
Wow
-15.3 mbar Offset.
I always thought that my +/- 13 mbar readings were already quite bad and actually a reason to throw the sensor away.
Hm,
My differential pressure sensor seems to be able to handle more; I've also seen values around 400 mbar.
Post30-10-2014, 18:12    Subject: Quote
Here is my 135,000km DPF, completely regenerated, and then I gave it full throttle. Difference in pressure sensor log.
 File size:  116.39 KB
 Viewed:  41581 times
Post20-06-2015, 12:14    Subject: Quote
Full-throttle log after forced regeneration, engine code CFFB (2.0 CR TDI, 103kW) in the Audi A3:
Odometer: 106000km
Ambient Pressure: 940mbar
Outdoor Temperature: 12°C
Ölaschevolumen: 50ml
Max. Differential Pressure in the Particulate Filter: 175hPa (equivalent to 175mbar) @ 4500rpm
 KDataScope Screenshot, Differenzdruck am DPF.
 File size:  194.93 KB
 Viewed:  33379 times
LOG-01-221-1111-3201-3251-3261-3291.CSV
 Log Differenzdruck, CFFB Motor
 File name:  LOG-01-221-1111-3201-3251-3261-3291.CSV
 File size:  26.27 KB
 Downloaded:  724 times
Tobi12345
dieselschrauber likes this.
Post01-09-2015, 16:59    Subject: Quote
Here is the differential pressure at the particulate filter of my 3.0TDI ASB 233PS, which has been tuned to approximately 270PS.
Particle filter ash loading 0.32. Filter has just completed a normal regeneration.
I am planning to clean the filter due to the extremely high differential pressure and exhaust gas backpressure.
I will be documenting my experiences here.
 File size:  99.22 KB
 Viewed:  30951 times
LOG-01-011-114-43C-1024.CSV
 File name:  LOG-01-011-114-43C-1024.CSV
 File size:  18.7 KB
 Downloaded:  728 times
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Tobi12345
Post09-09-2015, 16:45    Subject: Quote
Okay, here's a log showing a cleaned DPF:
Unfortunately, I haven't achieved the success I had hoped for.
It was 18°C with a surrounding pressure of 1009mbar.
The log is back in the 6th. Attempting a "Gang" on the AB with VMAX.
The DPF was discharged against the flow using a compressed air gun until no more came out, and then it was flushed with water and a garden hose.
I would really appreciate it if other owners of 3.0TDI engines also posted their values.
I might try cleaning it again, and then I'll use a DPF cleaner for help.
 DPF Differenzdruck 3.0 TDI V6
 File size:  126.62 KB
 Viewed:  8788 times
08.09.2015.CSV
 Log DPF Differenzdruck 3.0 TDI V6
 File name:  08.09.2015.CSV
 File size:  66.46 KB
 Downloaded:  1196 times
Albrecht
Post22-10-2015, 20:24    Subject: Quote
VL-Hochlauf in the 4th. {TEST_NAME} of another 3.0 TDI.
MWB 104 at the time of measurement: 0.20 l / 13g / 9g / 500km
Air pressure 989 mbar; Air temperature 11 °C
LL: 186 Tkm, no tuning
Also, the values are quite high, especially since the DPF hasn't been recently regenerated:
Delta-p 488 mbar @4300 U/min
I need to repeat the measurement with an empty filter at some point.
Normal regenerations occur at distances of >1100km.
 File size:  98.03 KB
 Viewed:  8741 times
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
Albrecht
Post05-02-2016, 21:11    Subject: Quote
VL-Hochlauf in the 4th. Measured the rate of regeneration.
MWB 104: 0.20 l / 10g / 6g / 0km
--> Question: How should the soot loading values after regeneration not be 0?
Air pressure 989 mbar; Air temperature 6 °C
LL: 189 Tkm, no tuning
max Δp 406 mbar @4300 U/min
 File size:  62.2 KB
 Viewed:  8416 times
Goisbart
Post11-03-2017, 0:30    Subject: Quote
MKB: BMM not tuned
LL: approximately 253,000 km
Air pressure: 969 mbar
Ambient temperature: 6 °C
Distance since regeneration: 170 km
Loading: 0%
Ash: 68g (Limit: 60g)
Logfahrt bergauf, 1533/min bis 4032/min
Temp. in the PF max. 498°C
Differential pressure max. 293 mbar
See attached CSV file.
In 2009, I had already logged data, at that time it was around 60,000 km, 16g ash and 534°C in the PF, with a maximum of 324 mbar. The pressure sensor was replaced at 155,000 km.
It seems that the 68g ash does not make a difference in the differential pressure. Are there any other features that indicate a necessary cleaning?
Previously, he would burn all 390 km of fuel. Now, it seems he's burning all 340 km. It might not be the soot loading; could I test with 30g of ash?
Greetings
LOG-01-11F-67F-687_k.csv
 File name:  LOG-01-11F-67F-687_k.csv
 File size:  20.35 KB
 Downloaded:  554 times
Petrol
Post30-03-2017, 20:12    Subject: DPF Back Pressure Normal Values Quote
MKB: CFGB, Passat 125KW DSG gearbox (Year 2011)
no tuning, no software update, 166,000 km
989 hPa Ambient Pressure Ambient Temperature 18 Degrees
Measurement blocks under menu: Engine Control are disabled!
Capacity: 100ml
Maximum 407 hPa pressure difference [Edit Admin: In my opinion, this is a bit too high for the mileage or engine oil volume]
Greetings, Petrol
messfahrt_r22_4Gang_BAB.CSV
 DSG Gang=4 bis 4300U/min dann weiter ohne "Gas"
 File name:  messfahrt_r22_4Gang_BAB.CSV
 File size:  2.89 KB
 Downloaded:  540 times
Georg_G
2012 Volkswagen Golf
Post28-09-2017, 13:10    Subject: Quote
Golf 6 Variant, 2.0 TDI CFHC, Year 2012, Mileage 150,000 km
Ölaschevolumen 80 ml
The images below show the differential pressure during three full-load accelerations, once shortly before regeneration with 18 g of soot mass, and once directly after regeneration with 0 g of soot mass.
The loaded state (18 g of soot mass) has a flue gas pressure approximately 50 mbar higher than the freshly burned, unloaded state.
 Differenzdruck frisch nach Regenerierung
 File size:  63 KB
 Viewed:  2607 times
 Differenzdruck kurz vor Regenerierung
 File size:  61.49 KB
 Viewed:  2424 times
ExiLi
Post22-05-2018, 10:11    Subject: Quote
MKB: CBBB, Passat 125kW DSG gearbox (Year 2009)
no tuning, and without a software update
Regeneration approximately every 1100-1200km
Loading status: 0%
Last regeneration 40km ago
Mileage: Calculated to be approximately 400,000 km. (Purchased in 2016 with "190,000 km", but according to the history, it had already exceeded 213,000 km in 2013.)
According to my knowledge, NO new DPF has been installed, as the part number and manufacturing date match the vehicle's year of manufacture. Whether a cleaning has taken place is unknown, as there are no visible cuts or signs of processing.
989 hPa Ambient Pressure, Ambient Temperature 25 degrees
Capacity: 240ml (Maximum 180ml)
286 mbar pressure difference at 4196 U/min in 3rd gear
When the transmission automatically upshifts to 4th gear at 4600 RPM, the differential pressure briefly increased to 326 mbar.
Unfortunately, the log file is corrupted, and I need to create a new one.
Ste.Bo
Karma: +90 / -0   Thank you, like it!
dieselschrauber and Mpire likes this.
Post17-10-2018, 17:12    Subject: Audi Allroad 3.0 TDI Engine Code: ASB Quote
Hello everyone,
I also wanted to share my results. Three times measured:
Before expansion:
MKB: ASB
LL: approximately 203,000 km
Air pressure: 1042 mbar
Ambient temperature: 32 °C
Distance since regeneration: 0 km
Loading: 0 / 0
Ashes: 0.56
Measured full acceleration in 5th gear. Highest value just before the critical point.
DPF Temperature: 537°C
Differential pressure max. 730 mbar
After rinsing and patting dry (there were really a lot of brown, crumbly pieces):
Air pressure: 1028 mbar
Ambient temperature: 28 °C
Loading: 0 / 0
Ashes: Reset to 0
DPF Temperature: 496°C
Differential pressure max. 423 mbar
A month later, the consumption of AB had noticeably increased again. Measurement without prior regeneration:
LL: approximately 205,000 km
Air pressure: 1002 mbar
Ambient temperature: 26 °C
Distance since regeneration: 1300 km
Loading: 16 / 4
Ash: 0.02
DPF Temperature: 522°C
Differential pressure max. 509 mbar
Greetings
Bo
No new posts P244B - Diesel Particulate Filter - Differential Pressure... General Tips
No new posts P244B Diesel Particulate Filter Differential Pressure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential pressure DPF vs. exhaust backpressure (and S... Diesel Engine Technology
No new posts DPF differential pressure slightly high Diesel Engine Technology
No new posts Differential Pressure & Backpressure: 3.0 TDI Comparison Diesel Engine Technology
No new posts Where is the differential pressure sensor located? Diesel Engine Technology
