Codierung AGM-Batterie | Posts 16+
Go to page: Previous  1, 2
Marcel
Post13-11-2018, 23:01    Subject: Quote
I looked around today, but I didn't find what I was hoping for (although that's probably also due to my current lack of skill/ability).
I do not have access to the Battery Management System (BMS) module (STG 61) or the battery charger module (STG 71), as it cannot detect these modules (see images 6, 7, and icon_cool.gif.
Instead of looking at the STG61 (battery management), I decided to examine the STG09 (central electronics), but I couldn't find anything related to the battery there. (See pictures 4 and 5).
I looked into the diagnostic interface (STG 19) a bit further and found some information related to my battery (see pictures 2 and 3). Apparently, they are really hidden and scattered throughout the control units.
Are these data all easily changeable for the new battery, or is there anything else I need to consider?
Is it possible for me to display my battery status in the same way that Rainer described in his post above? Or does my Audi not have that feature?
Best regards and a pleasant evening to you all.
Marcel.
 STG 71 - kein Zugriff
 File size:  109.51 KB
 Viewed:  847 times
 STG 61 - kein Zugriff
 File size:  116.74 KB
 Viewed:  897 times
 Steuergeräteübersicht
 File size:  100.14 KB
 Viewed:  861 times
 STG 09 - Zentralelektrik -> kein Anpassungskanal gefunden
 File size:  86.38 KB
 Viewed:  834 times
 STG 09 - Zentralelektrik -> Stichwortsuche nach "batterie"
 File size:  115.18 KB
 Viewed:  1018 times
 STG 19 - DIagnoseinterface -> Anpassungskanäle gefunden
 File size:  169.77 KB
 Viewed:  880 times
 STG 19 - Diagnoseinterface -> Stichwortsuche nach "batterie"
 File size:  144.6 KB
 Viewed:  905 times
Audi A3 8VA 2.0 TDI quattro Bj. 2013
Translated on 18-08-2026, 21:42.
Back to top Profile PM Email
Post14-11-2018, 20:01    Subject: Quote
The battery status and other related information should be found within the extended data of the respective control unit.
I would either install a battery of the exact same type or test beforehand to ensure that the desired setting actually works.
Translated on 18-08-2026, 21:44.
No new posts Battery Drain: Audi A2 8Z0 MJ 2002 Doc Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Care: Tips for Checking and Maintenance Technical Articles
No new posts Sebang Battery Coding: How To & Guide Electrical Systems, Vehicle Electronics, Multimedia
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts Coding a Second Car Battery: How To Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 3 TDI Battery: Buy Now & Save! Diesel Engine Technology
