chli1976 Profi-Schrauber
matthiasTDI96 Profi-Schrauber
30-11-2018, 7:25 Subject: Connecting rod bearing damage BLS |
Hi.
I don't find that typical either, since at least the engine block itself is found in several different models. I suspect that the owner may not have been very diligent with maintenance, or perhaps experienced a moment when the oil level was too low.
I would suggest looking into the price of a used one; that will save you the work and, in my opinion, is likely to be the most cost-effective option. If you do it properly, the bearings should be replaced and the shaft reworked... but I can hardly imagine that this would be economically viable.
Translated on 20-07-2026, 21:40.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
30-11-2018, 10:07 Subject: Connecting rod bearing damage BLS |
Hi there.
If you start with engine rebuilding, like honing the crankshaft... then you also need to hone the cylinder, replace the piston rings... that's the bare minimum, and it will definitely cost a four-digit amount, certainly not starting with the number "1".
Thanks to salvage yards, there are plenty of engine parts from the VW group available for relatively cheap prices. For example, when a friend's BKC (1.9 TDI 105PS) engine failed in his Seat Altea, we found a complete engine, except for the alternator, with all its attachments for €300 at a local salvage yard. We were able to test it while it was still installed, and for that price, it even came disassembled with a 4-week warranty. It's hard to find anything cheaper than that.
Translated on 20-07-2026, 21:42.
Profile PM Garage |
30-11-2018, 11:09 Subject: Connecting rod bearing damage BLS |
Edit:
I don't know if the connecting rod bearings tend to wear out at this mileage.
Of course, it's the connecting rod bearings and not the main bearings that tend to wear out prematurely in the BLS engine, as I wrote yesterday.
VCDS
Translated on 20-07-2026, 21:43.
07-12-2018, 19:05 Subject: Connecting rod bearing damage BLS |
Can someone tell me if this is bad?
The connecting rods, pistons, piston pins, and screws weigh:
Cylinder 1: 1410 grams
Cylinder 2: 1413 grams
Cylinder 3: 1414 grams
Cylinder 4: 1422 grams
VCDS
Translated on 20-07-2026, 21:44.
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
07-12-2018, 20:01 Subject: Connecting rod bearing damage BLS |
Schlimm? Für den maximal ruhig laufenden R4 Motor? Yes!
Für den Durchschnittsmotor eines Michel? No.
"12 grams or less than 1% is still within the tolerance for mass production, as far as I know. But it seems like a lot to me when I think about the specific weight of steel (connecting rods) or aluminum (pistons). You can almost see the volume with your own eyes?"
haithamina
Translated on 20-07-2026, 21:45.
