T4 2,5 Tdi , ACV Baujahr 2001 mal wieder Leistungsverlust! | Posts 48+
Go to page: Previous  1, 2, 3, 4
Post06-01-2019, 16:29    Subject: Quote
"I'm wondering if there are any differences in the static readings between the ambient air pressure and the actual boost pressure when using the old versus the new MAP sensor, and how the pressure diaphragm on the wastegate behaves."
Does the adjusting rod move in or out of the container when pressure is applied? icon_cool.gif
Translated on 12-07-2026, 12:16.
Jeeper-Thomas
Karma: +1 / -1   Thank you, like it!
2002 Volkswagen T4 Consumption
Post06-01-2019, 17:37    Subject: Quote
Ahhh okay.
The test has been performed, and the sensor value is higher than that of the previous one. The pressure switch is working correctly and doing what it's supposed to do.
However, what's much better is that I finally found the bug!
Please provide the latest log file.
Jeeper-Thomas
Post06-01-2019, 17:47    Subject: Error found! Quote
I read in another forum that the connector for the turbocharger control unit and the connector for the EGR valve are the same, differing only by a small extension cable!
Since I worked on the valves one by one during the replacement process, there's no way I could have mixed them up! Also, because the bus was running perfectly fine after I bought it, the problem couldn't have existed before.
So, it seems the only possibility left is that at one of the two workshops that had access to the vehicle, either the cables were incorrectly installed or, even worse, deliberately tampered with in an attempt to win back a customer. (I'm not going to dwell on that right now because I'm really angry about it...)
After swapping the cables and taking it for a test drive, the car felt completely different. It's working as it should again, and the turbo boost is back to normal.
Best regards, and I'm happy.
Thomas.
LOG-01-008-011-xxx.CSV
 File name:  LOG-01-008-011-xxx.CSV
 File size:  104.93 KB
 Downloaded:  305 times
Translated on 12-07-2026, 12:18.
Karma: +1344 / -0   Thank you, like it!
Post06-01-2019, 18:37    Subject: Quote
I'm not entirely convinced yet.
Which of the logs in the file are you referring to? The one from today at 3:45 PM? Then probably yes.
For safety's sake, I would disconnect the connector from either the N75 valve or the EGR valve (with the engine running) and check for any error messages.
Translated on 12-07-2026, 12:20.
Dawinchie
1997 Land Rover Discovery
Post06-01-2019, 21:42    Subject: Quote
@Jeeper-ThomasViewing profile: Jeeper-Thomas
Didn't I take a Screenshot of the distributor injection pump?
Am I missing something?
Well...
Select value block 0.
Then you can select the TDI timing.
Select ACV MSG 15.
(the VPE goes into its "default state").
But first, make sure it's properly warmed up (fuel temperature approximately 140) icon_smile_thumb_up.gif.
I would also check the possibility of swapping the connectors using a process of elimination.
It's possible, given that the valves are very close together.
Great, if it actually works icon_biggrin.gif.
Syncronaut
Syncronisation neu erfahren .
Translated on 12-07-2026, 12:21.
Post07-01-2019, 9:42    Subject: Quote
How do the readings from the altitude sensor and the pressure sensor compare when the system is stationary?
Translated on 12-07-2026, 12:23.
Jeeper-Thomas
Post07-01-2019, 20:31    Subject: Quote
@RuediViewing profile: Ruedi: Which measurement blocks are responsible for this?
The bus is still running great, and even on uphill sections where it previously went into limp mode, it hasn't stalled (limp mode). I will test the other things again in the next few days. I have to go back to work today, so there isn't much time left during the day...
Thomas.
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post10-01-2019, 13:46    Subject: Quote
If those two connectors were reversed, the interruption in the EGR cable harness would also have been registered as an error. I'm speaking from experience as an ACV owner.
Where was this information? At the very least, after Rainer pointed out a potential EGR valve issue in the very first response, someone could have looked into it.
Translated on 12-07-2026, 12:24.
Jeeper-Thomas
Post10-01-2019, 13:53    Subject: Quote
I have listed the identified errors here. However, the one you described has never occurred. This is likely because there was no interruption beforehand. And the AGR valve works in a similar way.
Thomas.
Translated on 12-07-2026, 12:25.
Tagessuppe
Post10-01-2019, 19:29    Subject: Quote
As I mentioned, I had already experienced this problem after a Volkswagen workshop removed and reinstalled the engine.
"AGR short circuit to ground."
But it's good that it's now working as it should.
Translated on 12-07-2026, 12:26.
Post10-01-2019, 20:37    Subject: Quote
If the valves are electrically identical, swapping the connectors will not affect the output stages in the MSG (Main System Generator) at all.
The turbocharger pressure control and the exhaust gas recirculation (EGR) system are working together in a fascinating way. The EGR system controls the operation of the turbocharger's wastegate valve: when EGR is desired, the turbocharger pressure is increased (if possible), and when high turbocharger pressure is needed, the EGR valve is opened.
Dawinchie
Post10-01-2019, 22:01    Subject: Quote
Herbert wrote:
If the valves are electrically identical, the output stages in the MSG will not notice anything if the connectors are swapped.
The turbocharger pressure control and the exhaust gas recirculation (EGR) system are working together in a fascinating way. The EGR system controls the operation of the turbocharger's wastegate valve: when EGR is desired, the boost pressure is increased (if possible), and when high boost pressure is needed, the EGR valve is opened.
Hi there, that's correct! No error entries.
I just tried it out on my car.
Logs are identical, and the loading process is lagging behind. icon_wink.gif
Syncronaut
Translated on 12-07-2026, 12:28.
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Central Locking Failure: A6 Doku 4B (10/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance loss Golf TDI PD, Year 2001, 115 hp Diesel Engine Technology
No new posts Performance Issues: Troubleshooting & Solutions Diesel Engine Technology
No new posts Injection Nozzles: Year of Manufacture On-Board Diagnostics (OBD)
No new posts Klatstartprobleme Passat 1.9 tdi Baujahr 01.96 Diesel Engine Technology
