Error code 005399 / P1517 - Short circuit to ground (Solution)
Post25-01-2019, 19:27    Subject: Error code 005399 / P1517 - Short circuit to ground Quote
The error code 005399 (P1517, 05399, 5399) - short circuit to ground - occurs across different models in engine control units of TDIs with piezo injector pumps.
The cause is a short circuit in one of the power diode elements. You can identify the faulty element by disconnecting the electrical connector from each PD element one by one and attempting to start the system.
Ratings - Error code 005399 / P1517 - Short circuit to ground
No new posts Short circuit Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P1351 General Tips
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Terminal 58d - Short circuit to ground Electrical Systems, Vehicle Electronics, Multimedia
No new posts Intake air temperature sensor (G72) - Short circuit to gr... On-Board Diagnostics (OBD)
No new posts Multiple temperature sensor failures, resulting in a shor... Diesel Engine Technology
No new posts High-pressure generator (G65) 009 - Ground interruption/s... Transmission, Chassis, Body & Interior
